Cisco 867VAE-K9 routing issue
TR65
Hello
I am having an issue with routing on a Cisco867 router. I am connecting it into my Virgin BB Router which is on 192.168.2.0. If I ping from VLAN1(same subnet) I can ping the router and and devices i put in VLAN1 all work but I am trying to move devices onto other VLANs. From the 867 router I am not able to ping the virgin router on 192.168.2.1 from any of the VLAN interfaces.
The virgin router is in port Fa0. I have tried with the port configured as Access and as Trunk config on the port.
I have also tired configuring a default gateway rather than an IP route and nothing seems to work
remove:
--> ip default-gateway 192.168.2.1
and add:
--> ip route 0.0.0.0 0.0.0.0 192.168.2.1
Also, make sure that the Virgin router has routes back to those Vlans on your 867 router.
