How to set a NAT on ipsec tunnel?
Imed
i setup an ipsec between a ciso router and a fortigate firewall.Tunnel is up in both device while the two LAN subnets are unable to ping each other.
i saw lot of articles and tuto and sounds confused about the necessity of NAT on cisco side!!!!!!
please let me know how far is the NAT important on IPSEC tunnel?
Here is the cisco config summary
Router(config)#do sh run
Building configuration...
Current configuration : 1437 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.10.20.2 10.10.20.20
ip dhcp pool my_lan
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key eve123 address 192.168.174.31
crypto ipsec transform-set fortigate esp-des esp-md5-hmac
mode tunnel
crypto ipsec profile phase2
set transform-set fortigate
set pfs group2
interface Tunnel10
ip unnumbered FastEthernet0/0
tunnel source 192.168.174.30
tunnel mode ipsec ipv4
tunnel destination 192.168.174.31
tunnel protection ipsec profile phase2
interface FastEthernet0/0
ip address 192.168.174.30 255.255.255.0
ip nat outside
duplex full
interface FastEthernet1/0
ip address 10.10.20.1 255.255.255.0
ip nat inside
duplex full
ip nat inside source list 99 interface FastEthernet0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.174.2
ip route 10.10.10.0 255.255.255.0 Tunnel10
access-list 99 permit 10.10.20.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
20 Replies 20
SURE it not work, the remote Peer tunnel IP is same as tunnel destination ?
no that wrong.
Imed
Thank you for response,
But what's wrong with it since they ping each other ?
ping with tunnel not meaning it work.
try ping ip tunnel with use source, it will failed.
what you need is using WAN interface as source in local peer and WAN interface of remote peer as destination.
Imed
that's what i am using:
  • source =cisco wan int
  • dest = fortigate wan int
I didn't get your point: tow device live in the same subnet may cause the prob.
That ok if you use wan interface as source destination
Only think now change tunnel ip to be
10.0.0.1 local peer
10.0.0.2 remote peer
that did'nt work too
share the last config
Router(config)#do show run
Current configuration : 1601 bytes
! Last configuration change at 12:25:04 UTC Tue Dec 6 2022
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool my_lan
dns-server 8.8.8.8
ip cef
no ipv6 cef
hash md5
group 5
mode tunnel
crypto ipsec profile pahse2
set pfs group5
set pfs group2
interface Tunnel10
ip address 172.16.0.1 255.255.255.252
ip nat outside
duplex half
ip nat inside
duplex full
interface FastEthernet2/0
no ip address
shutdown
duplex full
ip nat inside source list 10 interface FastEthernet0/0 overload
no ip http server
access-list 10 permit 10.10.20.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
please see above comment
friend I spent one hours see the config,
we talking about route-based VPN so the NAT will not effect,
there something elas
ip route 0.0.0.0 0.0.0.0 192.168.174.2 <<<- this is this IP ???
Welcome back friend,
It was a busy week, i ve just got the time to rebuild my lab. i think the cisco image i installed is corrupted i tried a different image.
And it works. i finally saw the traffic int both direction, i did not set any NAT setting on my tunnel int.
But the it keeps dropping.
Do ve any idea ?
i 've just unchecked the auto negociat option and it s fine now
keep dropping ?
how you know the traffic is dropping ?
