Cisco 870 Series ADSL/ Pots config
rosabenson
Hi everyone,
I have a Cisco 871 Adsl router (IOS C870-ADVSECURITYK9-M), Version 15.1(4)M6)
This will be connected to an adsl line for dialup to the ISP. I have used the configuration before, but for some reason I cannot get it to light up the PPP connection. Under the interface Virtual-PPP1 interface I used to have the command: pppoe-client dial-pool-number 1
But now it gives me an error when I want to configure it there.
config-if)#pppoe-client dial-pool-number 1
% Invalid input detected at '^' marker.
Any advice will be greatly appreciated:
version 15.1
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
service compress-config
service sequence-numbers
hostname WHATEVER
boot-start-marker
boot system flash
boot-end-marker
logging snmp-authfail
logging buffered 51200 warnings
enable secret 4 X8zyQatqYasFWjVyCf0nQwNNTGLAs9u5rn7Uq/bZ6c6
aaa new-model
aaa session-id common
clock timezone GMT 2 0
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.253
ip dhcp excluded-address 192.168.1.240
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
 default-router 192.168.1.254
 dns-server 192.168.1.254 8.8.8.8
 lease 0 2
ip cef
no ip bootp server
no ip domain lookup
ip domain name telkomsa.net
ip name-server 196.43.45.190
ip name-server 8.8.8.8
ip name-server 8.8.4.4
archive
 log config
  hidekeys
username admin privilege 15 password 7 12170003110A1E016E38212B262727
ip telnet source-interface Loopback0
ip tftp source-interface Loopback0
ip ssh time-out 60
ip ssh version 2
no crypto isakmp enable
interface Loopback0
 no ip address
interface ATM0
 no ip address
 load-interval 30
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 pvc 8/35
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
 ip address negotiated
 ip mtu 1452
 ip nat outside
 ip virtual-reassembly in
 ip tcp adjust-mss 1412
 ppp chap hostname WHATEVER
 ppp chap password 7 094A645A4616264756
 ppp pap sent-username WHATEVER
 no cdp enable
interface Vlan1
 ip address 192.168.1.254 255.255.255.0
 ip mtu 1452
 ip dns view-group dns
 ip nat inside
 hold-queue 100 out
interface Dialer0
 no ip redirects
 ip mtu 1492
 ip flow ingress
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 load-interval 30
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username WHATEVER...
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns view dnsfwd
 dns forwarder 196.43.45.190
 dns forwarding source-interface Loopback0
ip dns view-list dns
 view dnsfwd 10
ip dns server
ip nat inside source list 100 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Virtual-PPP1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list standard VTY
ip access-list standard access
logging facility local6
access-list 50 permit any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
snmp-server ifindex persist
snmp-server queue-limit notification-host 1
snmp-server enable traps tty
control-plane
banner motd ^CC
                   ///  CISCO \\\
                NO UNAUTHORIZED ACCESS
^C
line con 0
 session-timeout 5  output
 exec-timeout 120 0
 password 7 000A1612075A19034B32494D1C0B00
logging synchronous
 no modem enable
 transport preferred ssh
 stopbits 1
line aux 0
line vty 0 4
 session-timeout 10  output
 access-class 50 in
 exec-timeout 120 0
 privilege level 15
 transport input ssh
scheduler max-task-time 5000
ntp server 196.4.160.4
sntp source-interface Loopback0
end
Peter Paluch
Hello Rosa,
For a totally basic PPPoE-over-ADSL, I do not believe that using a Virtual-PPP interface in your case is the correct approach; this is used with L2TP targeted sessions.
You should correctly be using the Dialer0 interface just the way it is configured now, and add the following lines to your interface ATM0.1:
 pvc 8/35
You should totally remove the Virtual-PPP1 interface; you should not be needing it.
Can you give this a try?
Best regards,
Peter
Peter Paluch
Hello Rosa,
 pvc 8/35
Best regards,
Peter
Peter,
thank you very much! It is working like a charm.
