11-02-2007 02:12 AM - edited 03-03-2019 07:23 PM
I would appreciate if someone could please answer to following question:
What is the speed (MHz) of device Cisco 871-k9?
Thank you, Susanne
11-02-2007 06:26 AM
11-02-2007 07:48 AM
Cisco doesn't release the speeds, no. . .
But a quick check on Google when I had an 871 that worked showed that the processor either ran at 166 or 266MHz. I can't remember which.
The ease way you MAY be able to find out is to do a sh ver. . .it'll tell you the processor in the router. You can plug that into a quick Google search and sometimes come up with a number, unless it's a processor specific to Cisco (which, not all are).
edit:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC8272
Quick search of your processor. But as Paolo said, Cisco doesn't release the specific speed, and Google will sometimes only give a general speed.
11-05-2007 03:55 AM
Thank you for your reply and the attached document which will help to determine about what could be the clock speed.
For you others who reads this message: Please be aware that the pps in the performance document is calculated based on cpu load 100% plus the pps is only unidirectional. I recommend a CPU load not higher than 70% and divide the pps with 2 to get bidirectional(duplex).
Thank you,
Susanne
