Cisco 871 W
ichigo1661
Sorry, i'm really new to cisco world.
-Can I disable the wireless function of this router Cisco 871 W. What i want to do is to turn off the wifi signal and use cable connection only.?
Thanks.
rmcarthur
Hi Yusof, yes you can. From the cli go into the radio interface, DOT11 0 and issue a shutdown command.
Router#conf t
Router(config)#interface dot11 0
Router(config-if)#shutdown
Router(config-if)#end
Router(config)#end
Router#wr mem
Hope this helps
