Cisco 877 ADSL PADI Expired
ez9
I have a Cisco 877 and i want to register on it two ADSL lines. One PSTN and one ISDN.
I have successfully registered the PSTN line with this config:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp pap sent-username usename password 0 password
Then i tried to register the ISDN line. I connect my ISDN bridged modem on fa3 with this config:
interface Vlan3
no ip address
pppoe enable group global
pppoe-client dial-pool-number 88
interface FastEthernet3
 switchport access vlan 3
interface Dialer88
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 88
no cdp enable
ppp pap sent-username username password 0 password
The problem is that the ISDN line no registered and in debugs it shows the error 'PADI timer expired'. I then tried to shutdown the atm0 and dialer1 interfaces and the ISDN line comes up.
So i wonder if there is any pitfall in this config or i should add something more in my config in order to override this 'conflict'
Any help will be appreciated.
0 Replies 0
