Cisco 877 and Port Forwarding
panitaxx1
I have a cisco 877 with 3 vlans and and atm interface with a bvi interface.
Vlan 2 and 4 : are nat inside. two different subnets
Vlan 3: bridged directly to atm.
BVI1: nat outside. gets its ip address via dhcp.
I have some static nat port translations from bvi1 to some vlan4 hosts.
Everything works fine. The problem is that when I power cycle the router or the dsl (atm) goes down and then up the nat translations stops working. To work I have to erase the translations and create the again.
paolo bevilacqua
Try updating IOS.
