Bookmark
Subscribe
3217
Cisco 877 Router Adsl Bridge Mode ??
St3v3n-zn
Hi, I have the following config, I am trying to put the cisco 877 in bridge mode and let the device attached to the switchport handle all the negotiation and receive the public ip address, but for some reason this is not working, am I missing something ?
Thanks in advance...
Building configuration...
Current configuration : 877 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no ip routing
no ip cef
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Router#
jamie.grive
Well it seems a bit overkill to use a nice 877 router just for this!
The config looks right to me - have you tried a 'show spanning-tree' to make sure all ports are forwarding.
cprice
If the end device is the ISP modem, I wouldn't worry about configuring the ATM interface or bridge protocols. I would configure the ethernet interface for ip address negotiated and route accordingly.
I also agree with Jamie, that the 877 is a bit of an overkill when that can be configured for the ADSL service you have subscribed to. Unless it's VDSL, then you need different equipment.
