Cisco 877w Dual Vlan
Nish Vamadevan
Trying to setup Dual VLAN (Different Subnet for Wired and Wireless) on 877w for and seem to be stuck somewhere where VLAN2 is stuck on up/down
WIRED - Vlan1 - 192.168.1.1 / 24
WIRELESS - Vlan2 - 10.0.0.1 /24
I have disabled all the bridiging and all the BVI are removed.
Vlan 1 and Vlan 2 has the Above Subnet Configured.
Can someone point me in the direct direction on where I am going wrong? Or some kind of basic guide would be helpful.
Internet#sh dot11 asso
802.11 Client Stations on Dot11Radio0:
SSID [Fnode] : DISABLED, associated VLAN 2 is not active
Internet#
5 Replies 5
Reza Sharifi
Can you post your current confg?
Reza
Surendra BG
have you assigned VLAN 2 to any port and connected a PC to that port?? that time the VLAN 2 wil come up and then u can check the line and protocol status. when the VLAN comes up, the wireless clients will grab the IP and they will get connected.
Let me know how this works out for you!!
Surendra
Surendra BG
Thanks Surendra, It does work... I guess there is no way to dedicate VLAN 2 to Just for Wireless... Correct me If I am wrong, If VLAN2 is assigned to Dot11Radio0, it should be up/up right?
Reza, I am Posting part of my Config here, but it is running on Bridge-Mode.
If anyone can setup this box to serve WIRED and WIRELESS on Totally Seperate VLANs Without any Bridging, please do point me in the right direction.
Thanks!
dot11 ssid XXXX
   vlan 2
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 xxxxxxx
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
encryption vlan 2 mode ciphers aes-ccm
broadcast-key vlan 2 change 45
ssid XXXX
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
rts threshold 2312
interface Dot11Radio0.1
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
description Wired VLAN
no ip address
bridge-group 1
interface Vlan2
description Wireless VLAN
no ip address
bridge-group 2
interface BVI1
description Wired Network Range
ip address 192.168.1.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
interface BVI2
description Wireless Network Range
ip address 10.0.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge irb
Hi guys,
I'm trying to do the same here.
Ive got 2 VLANs and I'm trying to bridge with no luck
actulaly, if I stick everything into the same VLAN then that'll be okay too.
Can anyone help me as I tried the above and didn't work.
Have a look at the following as I have managed to do it.
First, you need to have a look at how I have managed to configure Wireless on the following URL, then follow the config below.
http://www.nish.com/2012/04/configure-wpa2-aes-ccmp-on-cisco-877w/
Mind you, If you are confused about the NAT Translation, I am not using the ATM Interface as I am using an External Modem, hence the NAT Translation is going out of VLAN20.
ip dhcp pool WIRELESS
   network 10.10.1.0 255.255.255.0
   default-router 10.10.1.1
   dns-server 208.67.222.222 208.67.220.220
ip dhcp pool WIRED
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
interface Vlan1
description WIRED VLAN INTERFACE
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan2
description WIRELESS VLAN 2
no ip address
interface BVI1
description WIRED VLAN BRIDGE INTERFACE
ip nat inside
ip nat inside source list WIRED interface Vlan20 overload
ip nat inside source list WIRELESS interface Vlan20 overload
ip access-list extended WIRED
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended WIRELESS
permit ip 10.10.1.0 0.0.0.255 any
Hope it helps.
