Cisco 877W error messages
maller
I've configured a Cisco 877W ADSL router working properly. Also I've configured a VPDN group for PPTP users .
All is working fine , but often in the log buffer there are these messages
Jan 11 17:27:14.726: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Jan 11 17:27:14.726: esw_mrvl_pdc_hardware_config failed on slot 0/0
Jan 11 17:27:16.234: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Jan 11 17:27:16.234: esw_mrvl_pdc_hardware_config failed on slot 0/0
I'm not sure about the meaning of these messages.
Do you know it?
thanks
lisa.hall
Level 2
Level 2
take a look at this document :
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857hig/eng/857inst.htm#wp1043584
If the cables are loosely connected or if the 4 cables are not plugged in correctly, you will see these error messages. check out this and shutdown any ports that do not have anything connected to them.
