BGP router or switch suggestion
jermz
I need a recommendation for a router or switch that can run BGP to act as an Internet edge router. I only need partial routing (let's say < 500 routes) with Gigabit interfaces. Any suggestions? I'm considering a cat 3750 with IP Services. Anybody use that model for BGP?
Jermaine
mheusinger
Level 10
Level 10
for only 500 routes you can use practically every router and switch supporting your other requirements.
You should apply the proper inbound and outbound filters to be sure an ISP failure will not get you in trouble. An example configuration would look like this:
router bgp 65000
network 1.1.0.0 mask 255.255.0.0
neighbor 3.4.5.6 remote-as 1
neighbor 3.4.5.6 maximum-prefix 2000
neighbor 3.4.5.6 prefix-list NoTrash in
neighbor 3.4.5.6 filter-list 1 out
no auto-summary
ip as-path access-list 1 permit ^$
ip prefix-list NoTrash deny 192.168.0.0/16 le 32
ip prefix-list NoTrash deny 172.16.0.0/12 le 32
ip prefix-list NoTrash deny 10.0.0.0/8 le 32
ip prefix-list NoTrash deny 1.1.0.0/16 le 32
ip prefix-list NoTrash permit 0.0.0.0/0 le 32
ip route 1.1.0.0 255.255.0.0 Null 0 250
assuming your network to announce would be 1.1.0.0/16
Hope this helps
Martin
thisisshanky
Level 11
Level 11
To use a switch such as 3750 with BGP enabled costs more $$$. I would spend that much money on a router that can do the same thing with additional memory added, in case you subscribe to more prefixes.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Yes, I understand the additional cost for the IP Services feature set. My equipment is located in a collocation facility where I have access to any number of ISPs via ethernet. I also don't plan on using WAN interfaces, so my main requirement is gigabit ports; I need at least four.
I do see the point about memory...
mheusinger
Level 10
Level 10
router bgp 65000
no auto-summary
Hope this helps
Martin
Yes, that's what I figured. I was hoping to hear from people that may have used the 3750 for BGP. Thanks for the sample config; it is close to what I had in mind.
