Cisco 878 dsl controller configuration
steve
I have a SDSL G.DMT service with Zen.
We have purchased an 878 and put a basic config on it.
It refuses to show even a CD led when connected up to the copper wire.
Has anyone got a sample config for the controller which shows all the lines needed to get a carrier detect from a UK supplier.
cheers
Steve
ps currently using a Speedtouch 605s, so the SDSL does work, but 'cos we cant get NAT off it, we decided to put a Cisco box in to replace.
sachinraja
Level 9
Level 9
Hello Steve,
Please refer to this URL:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857swcg/eng/preface.htm
it has all the configurations possible with a 878 router.. u need to look at the PPPoE or PPPoA config...
Hope this helps..
Raj
