Cisco 881-k9 and port forwarding, will this work?
Daniel Jansma
Hi Guys,
Before I will go live with this Router I want to know if this is going to work.
I got two questions:
1. I can't ping to a dns domain name like, www.google.nl form the cli. With my laptop is no problem wich got DHCP from router, so is this my misstake somewhere?
2. is my port forwarding going to work, see config.
I'm new in Cisco command line world so don't break me ;-) Thanks for your time!!!
! Last configuration change at 20:48:56 UTC Tue Jan 8 2013 by
! NVRAM config last updated at 21:04:03 UTC Tue Jan 8 2013 by
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-133882138
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-133882138
revocation-check none
rsakeypair TP-self-signed-133882138
crypto pki certificate chain TP-self-signed-133882138
certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
ip source-route
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp excluded-address 192.168.10.150 192.168.100.254
ip dhcp pool Test
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 213.144.235.1 213.144.235.2
lease 8
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1649C3SD
archive
path ftp://ipaddress/httpdocs/fiber_
write-memory
username admin privilege 15 secret 4 BLABLA
ip ftp username hello
ip ftp password typo
ip ssh version 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description WAN
no ip address
duplex full
speed 100
pppoe-client dial-pool-number 1
interface Vlan1
description LAN
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username USERNAME password 0 PASSWORD
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.10.6 1723 interface Dialer1 1723
ip nat inside source static tcp 192.168.10.253 444 interface Dialer1 444
ip nat inside source static tcp 192.168.10.3 25 interface Dialer1 25
ip nat inside source static tcp 192.168.10.3 443 interface Dialer1 443
ip nat inside source static tcp 192.168.10.4 3389 interface Dialer1 3389
ip nat inside source static tcp 192.168.10.150 5060 interface Dialer1 5060
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 23 permit 172.31.255.0 0.0.0.255
access-list 23 permit 84.246.25.0 0.0.0.255
access-list 23 permit 212.121.121.0 0.0.0.255
access-list 23 remark acl_remote_management
access-list 23 permit 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input all
end
What version of IOS are you running?
Add this to the config;
ip name-server 213.144.235.1
ip name-server 213.144.235.2
ip name-server 8.8.8.8 this is google's PUB DNS in case you have problems with your own DNS.
ip domain name (put the name server domain here - ns1.yourdomain.com) if you have one.
let me know how you go.
6 Replies 6
Emmanuel Valdez
Level 3
Level 3
Do you have public IP addrees on Dialer interface?
Can you post a show ip int brief please?
Regards.
Wel the ip on the dialer is as DHcp client from ISP. Can't do more on the dialer i think.
I get the same information when i do the show ip int brief. There i see the external ip.
Thanks for your quick reply.
Ahad Aboss
1. In config terminal type (config)#ip domain-lookup then hit enter.
2. Under interface Dialer1 you configured ip address negotiated which mean your ISP radius server will issue the IP. Once the PPP session is established, your port forwarding will work fine.
Hope this helps.
Ahad
1. When I ping to www.google.nl i receive:
Translating www.google.nl ... Domain server 255.255.255.255
Unregonized host .....
2. Thanks, i Will try It!
Emmanuel Valdez
Level 3
Level 3
What is the output form the sh ip int brief?
Maybe you did not received an IP public address from your ISP, if you don´t receive it you can not navigate to Internet.
Regards.
