Cisco 881: Need help with DHCP not assigning IP to VLAN 10 (beginner)
Mawk
Let me start by telling I'm a complete beginner, but I've tried reading posts on this forum, YouTube, Googling etc. to find an solution, but I'm stuck.
I have an static IP from my ISP, it's a /30 subnet, so I only have one IP for my WAN and a GW. I think I have assigned it correctly to my WAN port (Fa4), and I have created a DHCP pool and assigned Fa0 to VLAN 10.
Problem is that I can't get an IP assigned to my laptop which is connected to Fa0, but if I do an ipconfig /renew, I can see an ARP for a few seconds, but my laptop still has an 169.x.x.x IP-address.
The other problem is that I can't ping outside to the Internet.
I'm sure I have made a rookie mistake, but I can't for the sake of me, see what. The IP 200.50.70.10/30 is just an example and not my real IP-address.
Router#sh run
Building configuration...
Current configuration : 1337 bytes
! Last configuration change at 18:53:28 UTC Wed Feb 6 2036
! NVRAM config last updated at 19:03:10 UTC Wed Feb 6 2036
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool VLAN10pool
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1604911J
interface FastEthernet0
 description Name: Internal ID: VLAN10
 switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description Name: WAN ID: 32711223
 ip address 200.50.70.10 255.255.255.252
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan10
 ip address 10.10.10.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 200.50.70.9
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
scheduler max-task-time 5000
end
Router#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa1, Fa2, Fa3
10   VLAN0010                         active    Fa0
20   VLAN0020                         active
30   VLAN0030                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Looking for all the help I can get.
Thanks.
I don't want to be redundant, and I think NAT has been mentioned before, but make sure the lines marked in bold are in your configuration:
Router#sh run
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip source-route
dns-server 8.8.8.8
ip cef
no ipv6 cef
spanning-tree portfast
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
no ip http server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 10.10.10.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
16 Replies 16
Leo Laohoo
Portfast is not enabled.
The port is UP and enabled, not sure why it didn't show in the running-config.
balaji.bandi
Where is your PC connected ? what Port ?
ignore my question you have conected laptop to Fa0, missed it..need cofffeeee
BB
Yes, Fa0 :)
Mawk
Router#sh int desc
Interface                      Status         Protocol Description
Fa0                            up             up       Name: Internal ID: VLAN10
Fa1                            down           down
Fa2                            down           down
Fa3                            down           down
Fa4                            up           up     Name: WAN ID: 32711223
NV0                            up             up
Vl1                            down           down
Vl10                           up             up
Router#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.10.10.1              -   f0f7.55d0.7b72  ARPA   Vlan10
Internet  10.10.10.19             1   0021.cc41.b2bb  ARPA   Vlan10
Internet  200.50.70.10           -   f0f7.55d0.7b76  ARPA   FastEthernet4
But if I check on my laptop, I still have an 169.x.x.x address, and the ARP is gone in a few seconds.
I'm not sure what I did, but I corrected the timezone and clock, and I have now received an correct IP-address on my laptop, not sure if this was the issue? I did nothing more than change the clock and adjust to the correct timezone.
lekeplass1-r1#sh ip arp
Internet  10.10.10.23             0   0021.cc41.b2bb  ARPA   Vlan10
Internet  200.50.70.9           0   Incomplete      ARPA
I still can't ping outside, to the Internet though. I'm sure I'm just missing something simple.
From router console are you able to ping ISP Side IP address ? before we proceed further ?
post the ping output from router to
ping 200.50.70.9
BB
No, I'm not able to ping the gateway (ISP).
Router#sh int desc
Fa1                            down           down
Fa2                            down           down
Fa3                            down           down
NV0                            up             up
Vl1                            down           down
Vl10                           up             up
Router#sh ip int bri
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              200.50.70.10   YES manual up                    up
NVI0                       unassigned      NO  unset  up                    up
Vlan1                      unassigned      YES unset  down                  down
Vlan10                     10.10.10.1      YES manual up                    up
Router#sh arp
Router#ping 200.50.70.9
Sending 5, 100-byte ICMP Echos to 200.50.70.9 timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#sh run
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip source-route
dns-server 8.8.8.8
ip cef
no ipv6 cef
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Seb Rupik
Hi there,
Try adding the domain-name to the lease. I have seen some clients refuse a lease if it is not set:
   domain-name example.com
cheers,
Seb.
Thanks, I've done this now, but I actually got an correct ARP from my laptop now and it assigned an IP to it after I changed the timezone and adjusted the clock. Not sure if this was the case or why it suddenly worked.
Still, I can't reach the Internet or ping Google DNS.
As suggest other my post ping to ISP IP address and confirm and once that is confirmed.
we need to add NAT rules for the same to work.
BB
Yeah, I can't ping, posted an reply.
I'm kind of overflooded with information at the moment, mind pointing me in the correct direction regarding the NAT rules?
make sure your configuration looks exactly like this:
Router#sh run
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip source-route
dns-server 8.8.8.8
ip cef
no ipv6 cef
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
