Cisco 881 number of vty lines
sumit mehta
I have a Cisco881-k9 model router and the problem i am facing is with the number of vty lines it just shows 5 vty lines(i.e 0 to 4) to be configured .
When i try and configure the line vty 5 it says invalid input . Is it a Hardware Limitation for this model or the change of ios image would solve the purpose.
Please find the show version for the router as below
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 19:52 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
pgdl194 uptime is 1 week, 5 days, 16 hours, 4 minutes
System image file is "flash:c880data-universalk9-mz.150-1.M5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX160882LY
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
124160K bytes of ATA CompactFlash (Read/Write)
Could you please help me on this ..?
Thanks in advance
11 Replies 11
sumit mehta
Could someone please help ?
The 880 only support 5 vty lines. Why you need more?
There is a requirement in which we need more then 5 vty lines. Three for the internal access and three for the Cari access for the client.
Many Thanks for your reply Paolo
So its a hardware limitation and not an ios one right  ?
This is a software limitation decided by Cisco and thatt cannot be overriden by the user.
Thanks for the nice rating and good luck!
Is it possible to override this by changing the ios ?
Again: why is that you need more vty lines ?
We need more vty lines due to a requirement to give the client access to the router on 3 ports through the rotary command on those lines.
and we need to have 3 vty lines reserved for our internal access as per the design guidelines.
so we require 6 vty lines
To be honest with you, 6 users accessing the router simultaneously, seems exaggerated for such a small branch router.
You can try to talk to Cisco, but usually not much comes out of similar feature requests.
Many many thanks for your help Paolo
I will try to talk to CISCO regarding this
amigomnemonik
0 is counted as 1.
Sent from my iPhone
