Cisco 881 Port forwarding
matthew_shin
I am trying to setup port forwarding for our DB server.
Forwarding from outside to 172.16.10.100 for port 1433 is required.
We are using Cisco 881 for TPG EFM and current running config as below.
Our public IP is x.x.x.x and DB server is 172.16.10.100.
Internet works fine but 1433 port is not forwarding to the server from outside and I'm not able to access RDP to the server too.
Please correct settings for me.
hostname router1
boot-start-marker
boot-end-marker
enable secret 5 $1$fTRI$bgFgMkdStoAKC2Xh3cwD01
enable password router1
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 172.16.10.1
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 172.16.10.100
ip dhcp excluded-address 172.16.10.101
ip dhcp pool NET-POOL
 import all
 network 172.16.10.0 255.255.255.0
 default-router 172.16.10.1
 dns-server 203.12.160.36
 lease 9
no ip domain lookup
ip domain name router1.local
ip name-server 203.12.160.35
ip name-server 203.12.160.36
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FGL1821243Q
username admin privilege 15 secret 5 2wf23sdas
ip ssh time-out 60
ip ssh rsa keypair-name sshkeys
ip ssh version 2
ip ssh pubkey-chain
  username admin
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
 ip flow ingress
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Vlan1
 description $ETH_LAN$
 ip address 172.16.10.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Dialer0
 no ip address
 no cdp enable
interface Dialer1
 mtu 1492
 ip ddns update DDNS
 ip address negotiated
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1436
 dialer pool 1
 ppp chap hostname xxxxx@pig.tpg.com.au
 ppp chap password 0 xxxxxx
 ppp pap sent-username xxxx@pig.tpg.com.au password 0 xxxxxx
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list ACL_NAT_ALLOW interface Dialer1 overload
ip nat inside source static tcp 172.16.10.100 3389 interface Dialer1 3389
ip nat inside source static tcp 172.16.10.100 1433 interface Dialer1 1433
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended ACL_NAT_ALLOW
 permit ip any any
 permit tcp any any eq 1433
 permit tcp any any eq 3389
 permit tcp any any
 permit ip 172.16.10.0 0.0.0.255 any
 permit tcp any any eq www
 permit tcp any host 172.16.10.100 eq 1433
 permit gre any host 172.16.10.100
ip access-list extended ACL_OUTSIDE-to-INSIDE
 permit tcp any any eq 22
 permit tcp any any eq 443
 permit icmp any any echo
 permit icmp any any echo-reply
 permit icmp any any ttl-exceeded
 permit icmp any any unreachable
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit esp any any
 permit tcp any any eq telnet
 permit tcp any any
 permit udp any any
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 172.16.10.0 0.0.0.255
access-list 1 permit any
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 55 permit 203.12.160.5
access-list 55 permit 172.29.0.3
access-list 55 permit 172.29.0.4
access-list 55 permit 172.29.0.10
no cdp run
snmp-server community tpgframe RO 55
snmp-server enable traps tty
ghostinthenet
Level 7
Level 7
I can't see anything wrong with the NAT forwarding in this configuration. What happens when you try the following from the router's CLI?
telnet 172.16.10.100 1433 /source-interface Dialer1
telnet 172.16.10.100 3389 /source-interface Dialer1
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
6 Replies 6
ghostinthenet
Level 7
Level 7
We've been usnig the server for many years and only we did is changing the router. Port 1433 and 3389 should be open on the server.
Any other ideas?
Part of this was for testing the port and the other was for testing the routing. Were all four commands successful from the router?
It's working now. I don't know why. It didn't work with this settings last night, but now it's working. Thank you very much for your help.
michael o'nan
Level 4
Level 4
That line of config should port forward a connection coming from Dialer1 on port 1433 to 172.16.10.100. Are you sure the server is listening on port 1433?
I havent' checked it, but it's been running ok before we changed the Router. We used to have ADSL with normal ADSL modem and we changed Internet service to Ehternet so we changed the router. We are usnig reservation software for hotel and software provider said that port fowarding needs to be configured on the router.
Do you have any idea?
