Cisco 881 router is not supporting bgp
noumanqazi
I have cisco 881 ISR router  with c880data-universalk9-mz.124-24.T4.bin.
When I try to run bgp it is showing error . and showing other protocols but not bgp.
How can I enable support for bgp in this router
thanks
Nouman
You would need to have CISCO881-SEC-K9, currently you only have CISCO881-K9.
You would need to purchase the software upgrade to upgrade your router to Advanced IP Services.
Here is the data sheet for your reference:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.html
Here is the part# for the upgrade:
SL-880-AIS (upgrade option)
Cisco 880 Advanced IP Services Image Feature License
7 Replies 7
Jennifer Halim
Looks like you might have been running "Advanced Security" feature sets, instead of "Advanced IP Services".
To run BGP, you would need to run "Advanced IP Services" feature set software for 881 router.
Hope that answers your question.
Thanks for the reply;
As Per Cisco IOS software advisor ; the following is IP advance service IOS;
12.4(24)T3
c880data-universalk9-mz.12.4-24.T3
and I download the same train i.e
Can you please advise which software will work for me.
Nouman
Please also find show version from router.
Pls kindly post the output of "show version"
yourname>show version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 12.4(24)T4,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 15:45 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
yourname uptime is 21 hours, 7 minutes
System returned to ROM by reload at 10:25:28 UTC Sat Oct 9 2010
System image file is "flash:c880data-universalk9-mz.124-24.T4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 249856K/12288K bytes of memory
Processor board ID FCZ1425922N
5 FastEthernet interfaces
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
rsachin574
use this command in config mode license boot module c880-data level advipservices and after saving the configuration reload the router.
