Cisco 886va on Telekom Buisiness 25 VDSL pppoe-passthrough
schmidt.tobias
I need to degrad my Cisco 886va to a VDSL Modem and need help doing it.
tried to find a config with bridge enabled for VDSL but I have no luck.
Here is my current config, perhaps somebody could modifie it to use it only for
pppoe-passthrough.
Cisco886va#show run
Building configuration...
Current configuration : 3427 bytes
version 15.2
no service pad
service timestamps log datetime localtime
hostname Cisco886va
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 4096
enable secret 4 ****************
no aaa new-model
memory-size iomem 10
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip gratuitous-arps
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 10.1.0.1 10.0.0.149
ip dhcp excluded-address 10.1.0.170 10.0.0.254
ip dhcp pool local
network 10.1.0.0 255.0.0.0
default-router 10.1.0.254
dns-server 10.1.0.254
domain-name zsz.intern
ip dhcp pool Server
host 10.1.0.170 255.255.255.0
client-identifier 0ab0.0c6c.01c4.d2
client-name server
ip domain name soho.intern
ip inspect name myfw tcp
ip inspect name myfw udp
ip cef
no ipv6 cef
license udi pid CISCO886VA-K9 sn FCZ1647C0NH
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
interface Ethernet0.7
description VDSL Internet Verbindung - VLAN 7 tagged
encapsulation dot1Q 7
no ip route-cache
pppoe enable group global
pppoe-client dial-pool-number 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
description Gastnetz
switchport access vlan 2
no ip address
no cdp enable
interface Vlan1
description Lokales LAN
ip address 10.1.0.254 255.255.255.0
interface Vlan2
description Gastnetz (FastEthernet3)
ip address 172.16.100.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
description DSL Einwahl Interface
ip address negotiated
ip access-group 111 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
ppp authentication pap callin
ppp chap hostname ****
ppp chap password 0 ****
ppp pap sent-username ***** password 0 ******
ppp ipcp dns request
ppp ipcp mask request
ppp ipcp route default
no cdp enable
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 10.1.0.2 443 interface Dialer0 443
ip nat inside source static 10.1.0.2 217.91.227.182
access-list 23 permit 10.1.0.0 0.0.0.255
access-list 101 permit ip any any
access-list 101 permit icmp any any
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 111 permit ip any any
access-list 111 permit udp any any
access-list 111 permit tcp any any
access-list 111 permit icmp any any
dialer-list 1 protocol ip list 101
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
end
Thank you very much for your Help
Cheers
Tobi
paolo bevilacqua
For easy results in an economical way, for bridging use the modem given by ISP.
Tried to get a Provider V-DSL2 Modem but the only product the German Telekom has to offer is a Speed Port Router with default enabled PPPOE passthrough ... as I know this is not the best choice when you try to get a stable VPN site 2 site connection .... I also found a Zyxel device which is also a router and can be configured to a pppoe passthrough device ... but what I couldn't found is a not discontinued VDSL2 Modem.
