Cisco 887 ADSL Router Internet Access
paul.hepburn
Hi all.
I have a Cisco 887 ADSL router configured to allow internet access for internal users. Currently we are in the middle of a test week for a big event we have coming up. The setup is as follows:
ISP ----- On site ADSL line ----- Cisco 887 router ----- Building patching ----- Cisco 2901 router ----- Internal switched network.
We are using the Cisco 887 router to simulate a WAN connection, of which a device will be provided at the event by an ISP.
The Cisco 2901 has internal I.P. address of 192.168.5.254/24 and then the rest of the internal network sits behind this. The 2901 also has the I.P. address 79.173.156.178/29 assigned to Gi0/0 which connects to Fa1 on the 887. The 887 has an I.P. address of 79.173.156.177/29 assigned to vlan 1 and is set to negotiate an I.P. address from the ISP. I hope this makes sense.
Our issue is that we cannot access various websites; some work fine, such as Google and Cisco but others like Yahoo and National Rail do not, just a white screen and a spinning circle inside the web browser.
I have connected a cheap and nasty Netgear N300 to the ADSL line this morning and tested it in exactly the same way as specified above and the was no issue, so the problem has to be with the 887.
I have tried changing the MTU sizes on the atm and dialer interfaces but it doesn't seemed to have helped.
I am also getting the error: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Dialer1: the fragment table has reached its maximum threshold 16 from time to time. I've read a bit about this online but I'm more of a switching guy, not a router!
Please see below for a running configuraiton of the 887. Any help will be greatly appreciated!
WiMAX#show run
*Feb 26 11:27:20.471: %SYS-5-CONFIG_I: Configured from console by console
WiMAX#show run
Building configuration...
Current configuration : 1894 bytes
! Last configuration change at 11:27:20 UTC Wed Feb 26 2014
version 15.2
no service pad
hostname WiMAX
boot-start-marker
boot-end-marker
enable secret 4 .6lkCGsujvoDd5iw9hZeeNjIbVKL7zmu1mtejfCdpU2
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
request-dialin
  protocol l2tp
license udi pid CISCO887VA-SEC-K9 sn FGL172521RV
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
mtu 1400
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
  pppoe-client dial-pool-number 1
interface FastEthernet0
mtu 1400
no ip address
duplex full
speed 100
interface FastEthernet1
mtu 1400
no ip address
interface FastEthernet2
mtu 1400
no ip address
interface FastEthernet3
mtu 1400
no ip address
interface Vlan1
ip address 79.173.156.177 255.255.255.248
ip nat inside
ip virtual-reassembly in
interface Dialer1
mtu 1400
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname !"£$%^&*()
ppp chap password 0 !"£$%^&*()
ppp pap sent-username !"£$%^&*() password 0 !"£$%^&*()
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.0.0 255.255.0.0 79.173.156.178
access-list 1 permit 79.173.156.0 0.0.0.255
no cdp run
control-plane
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
password !"£$%^&*() logging synchronous
login
transport input all
ntp server 132.163.4.102
end
Hitesh Vinzoda
Level 4
Level 4
Hi dude,
add this command to your dialer interface
int dia1
ip tcp adjust-mss 1360
Hitesh
Pls rate useful posts
