Cisco 887 - Dialer interface counters
Hi all!
We have recently deployed several Ciso 887VAW (IOS 15.1(4)M4) to customer premises and I have come to realise counters show extremely high (not at all accurate) output rate and packets on all of them.
Any information as to why this might be?
Thanks!!
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is *****************
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:28:59
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
  5 minute input rate 1194135000 bits/sec, 11 packets/sec
  5 minute output rate 155545690897225000 bits/sec, 280977318174069 packets/sec
     17487 packets input, 253405947124 bytes
     4746306992316890012 packets output, 3756527703073020612 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 1022 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 3/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer1
  Vaccess status 0x44
  Bound to ATM0 VCD: 1, VPI: 8, VCI: 35, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 4w1d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 16000 bits/sec, 11 packets/sec
  5 minute output rate 891500816849912000 bits/sec, 684857346280161 packets/sec
     19253220 packets input, 7557005747 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    7002144625030736694 packets output, 13117493468545627574 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Giuseppe Larosa
Hello Vasko,
it should be a SW bug without any real impact ( cosmetic).
Similar issues have been already reported in the forums.
To be noted the number are so high that are totally unreal. This should be something easy to detect during IOS beta testing.
Hope to help
Giuseppe
That's what I'd figured. I will then have to plan for IOS upgrade at some point.
Thanks, Giuseppe.
