Cisco 1760 with AT&T Dsl connection
chiltonpr
Im having an issue with the cisco 1760 router, every time the ip address from the A&TT change. I need restart the adsl Wic for it to be able to get another ip address.
here is my config, any sugestion will be appreciate.
version 12.3
service nagle
no service pad
service tcp-keepalives-in
service timestamps debug datetime localtime show-timezone year
service timestamps log datetime localtime show-timezone year
hostname WAN1760
boot-start-marker
boot-end-marker
logging buffered 16384 debugging
clock timezone est -5
clock summer-time est recurring
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp ping packets 5
ip dhcp ping timeout 5000
ip dhcp pool DSL_DHCP
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 68.94.156.1 68.94.157.1
   default-router 192.168.1.1
ip domain name bori2.com
ip name-server 68.94.156.1
ip name-server 68.94.157.1
vpdn enable
vpdn-group pppoe
request-dialin
  protocol pppoe
username XXXXXXXX privilege 15 password 0 XXXXXXXXXX
username XXXXXXX privilege 15 password 0 XXXXXXXXX
interface FastEthernet0/0
description internal interface
ip nat inside
ip tcp adjust-mss 1452
no ip mroute-cache
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
no ip address
shutdown
interface ATM1/0
description DSL interface
mac-address xxxx.xxxxx.xxxx
no ip address
ip dhcp relay information trusted
no ip mroute-cache
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
pvc 0/35
  random-detect
  pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname XXXXXXXXXXXXXX@att.net
ppp chap password 0 XXXXXXXX
ppp pap sent-username XXXXXXXXX@att.net password 0 XXXXXXX
ppp ipcp dns request accept
ppp ipcp address accept
ip nat inside source list DSL_ACCESSLIST interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip access-list extended DSL_ACCESSLIST
permit ip 192.168.0.0 0.0.255.255 any
logging source-interface FastEthernet0/0
logging 192.168.1.100
snmp-server community private RW
snmp-server community public RW
snmp-server community xxxxxxxx RW
snmp-server enable traps pppoe
snmp-server enable traps syslog
line con 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
password XXXXXXXXX
login local
transport input all
line vty 5 15
password xxxxxxx
login local
transport input all
End
Gabriel Hill
Hello Hitlon,
Sounds like a bug to me.  If you post your "show ver" here I will look on the bug toolkit.
Thanks Gabriel, here is the show version
WAN1760#show version
IOS (tm) C1700 Software (C1700-ENTSERVICESK9-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 12-Dec-05 20:31 by evmiller
Image text-base: 0x8000816C, data-base: 0x817A694C
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-ENTSERVICESK9-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
WAN1760 uptime is 3 hours, 55 minutes
System restarted at 10:55:28 est Tue Feb 5 2013
System image file is "flash:c1700-entservicesk9-mz.123-17a.bin"
cisco 1760 (MPC860P) processor (revision 0x500) with 114688K/16384K bytes of memory.
Processor board ID FOC07451J3K (2564901177), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
1 ATM network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Hilton,
This kind of jumps out at me
CSCdy26008 -Failure to remove negotiated IP address
Symptoms: The negotiated IP address is not cleared from an asynchronous
interface when a call ends, even though the IP address is returned properly to
the IP peer pool.
Conditions: This symptom is observed when the peer is configured to dial in to
the network access server (NAS) and to obtain an IP address through IP Control
Protocol (IPCP) negotiations with the NAS. The NAS is configured with pools of
IP addresses to be allocated to the peer when the peers generate a PPP call to
the NAS. The NAS is also configured to authenticate the peer through RADIUS.
Workaround: There is no workaround.
A lot of older 12.2 / 12.3 images are affected by this, though your IOS version isn't listed, that doesn't mean it is excluded.
I would suggest upgrading to one of the newest 12.4 releases and seeing if that clears your issue up.
-Gabriel
Please Rate if post is helpful.
Thanks a lot will upgrade ASAP
