Cisco 887 SIP pass-through
ipgatewaypl
I have a Cisco 877 router and I configured it with the CP Express, however it isn't allowing pass-through for SIP.
How can I fix this? SIP devices cannot register. However they can make oubound calls no problem.
This is the config of the router.
Current configuration : 7498 bytes
! Last configuration change at 21:01:27 PCTime Fri Dec 16 2011 by mark
! NVRAM config last updated at 21:01:28 PCTime Fri Dec 16 2011 by mark
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname home
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5
no aaa new-model
memory-size iomem 10
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-2300806995
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2300806995
 revocation-check none
 rsakeypair TP-self-signed-2300806995
crypto pki certificate chain TP-self-signed-2300806995
 certificate self-signed 01
  (removed)
        quit
no ip source-route
ip dhcp excluded-address 192.168.12.1 192.168.12.29
ip dhcp excluded-address 192.168.12.61 192.168.12.254
ip dhcp pool ccp-pool1
   import all
   network 192.168.12.0 255.255.255.0
   dns-server 203.12.160.35 203.12.160.36
   default-router 192.168.12.1
ip cef
no ip bootp server
ip name-server 203.12.160.35
ip name-server 203.12.160.36
no ipv6 cef
license udi pid CISCO887W-GN-A-K9 sn FGL154821B8
username mark privilege 15 secret
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-cls-insp-traffic
 match protocol cuseeme
 match protocol dns
 match protocol ftp
 match protocol h323
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol netshow
 match protocol shell
 match protocol realmedia
 match protocol rtsp
 match protocol smtp
 match protocol sql-net
 match protocol streamworks
 match protocol tftp
 match protocol vdolive
 match protocol tcp
 match protocol udp
 match protocol sip
class-map type inspect match-all ccp-insp-traffic
 match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-all ccp-invalid-src
 match access-group 100
class-map type inspect match-all ccp-icmp-access
 match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
 match protocol http
policy-map type inspect ccp-permit-icmpreply
 class type inspect ccp-icmp-access
  inspect
 class class-default
  pass
policy-map type inspect ccp-inspect
 class type inspect ccp-invalid-src
  drop log
 class type inspect ccp-protocol-http
  inspect
 class type inspect ccp-insp-traffic
  inspect
 class class-default
  drop
 class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
 service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
 service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface BRI0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description $ES_WAN$$FW_OUTSIDE$
 ip flow ingress
 pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip unnumbered Vlan1
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
 ip address 192.168.12.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly
 zone-member security in-zone
 ip tcp adjust-mss 1412
interface Dialer0
 description $FW_OUTSIDE$
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1452
 ip flow ingress
 ip nat outside
 zone-member security out-zone
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname
 ppp chap password
 ppp pap sent-username
 no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.12.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip host 202.62.157.122 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
 Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
 login local
 no modem enable
 transport output telnet
line aux 0
 login local
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
0 Replies 0
