Cisco 887 slow Wan
Michal Trembacz
I have a couple of 887VA routers under my management. I noticed that none of them is allowing for bigger than 10 Mbit/s transfers via WAN link despite being synced with ie 15 Mbit/s or 17 Mbits/s.
I tried different IOS images and ADSL firmwares but it does not change anything.
#show controllers vdsl 0
Firmware        Source          File Name (version)
VDSL            user config     flash:vdsl.bin-A2pv6C035j1 (10)
Modem FW  Version:      120330_1738-4.02L.03.A2pv6C035j0.d23j
Modem PHY Version:      A2pv6C035j0.d23j
Vender Version:         Ap6v35j.23j 68
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            15354             0              1021
As you can see modem syncs with 15 M. I should practically get that speed sometimes (off peak hours). I measure that by speedtest.net but also tried to download via ftp from ISP's server etc. Never exceeded 10 Mbits. I have a 3 more routers connected to same ISP (Eircom Ireland) and same problems.
Is there anything on 887VAs that would stop reaching maximum bandwidth ?
I attached example config - dont look at acls as it was mostly removed. Also couple of objects etc to not include ip addresses.
#show interfaces fastEthernet 0
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 442b.03cd.7a9a (bia 442b.03cd.7a9a)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
Michal Trembacz
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.2(3)T1, RELEASE SOFTWARE (fc1)
Abzal
Level 7
Level 7
Ask your ISP about this issue. Check SLA agreement with them.
Regards.
Best regards,
Abzal
When I connect stock router that comes from ISP works at full speed.
