Many NAT in a single router
Mero Cisco
I have got a cisco 1841 router. I need to do many nat. I have got a lots of virtual interface on this router. How many nat inside and outside does it supports ? Can I do more than one nat insdie and outside in different virual interfaces on the same single router.
Mero
cadet alain
yes you can have many inside and outside NAT interfaces.
Regards.
Alain
cadet alain
Regards.
Alain
just adding to Cadets answer:
When you have multiple outside NAT interfaces you have to make sure that you use the right translation for the right interface. For that you have to use route-maps where you can control for which interface a NAT-rule should be used.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
