Issue with route-map
Shahab Khan
I was doing some testing & came across a picular issue. 3 nos. of routers connected to each are running EIGRP. I create 5 prefix-list for some networks.
I call these prefix-list in route-map. The syntax of the same is given below.
Router# show route-map rm-man-eigrp-B-out
route-map EIGRP_Out, deny, sequence 10
  Match clauses:
    ip address prefix-lists: eigrp-deny
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map EIGRP_Out, deny, sequence 20
  Match clauses:
    ip address prefix-lists: eigrp-deny-global ! Global subnets
  Set clauses:
route-map EIGRP_Out, permit, sequence 30
  Match clauses:
    ip address prefix-lists: eigrp-permit
  Set clauses:
route-map EIGRP_Out, permit, sequence 40
  Match clauses:
    ip address prefix-lists: eigrp-permit-global
  Set clauses:
After redistributing the route-map in EIGRP, I noticed that all routes are getting denied if am adding comment (in this case: ! Global Subnet).
What I want to know that is it possible to add comment like this or not. I have tested it now 2821 & ASR1002 routers.
Rahul Kukreja
I tested this on 2951 running 15.1(4)M1 code - it gives me the parser error when I execute the command although the command is accepted.
h323cucm8#sh ver | i .bin
System image file is "flash:c2951-universalk9_npe-mz.SPA.151-4.M1.bin"
h323cucm8#sh ver | i 29
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9_NPE-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
h323cucm8 uptime is 1 hour, 29 minutes
Cisco CISCO2951/K9 (revision 1.1) with 479232K/45056K bytes of memory.
*0        CISCO2951/K9          xxxxxxxxxxx
Technology Package License Information for Module:'c2951'
h323cucm8#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
h323cucm8(config)#route-map test deny 10
h323cucm8(config-route-map)#match ip add prefix-list test1 ?
  WORD  IP prefix-list name
h323cucm8(config-route-map)#match ip add prefix-list test1 ! test2
% Ambiguous command:  "match ip add prefix-list test1 ! test2" >>>>>>>>>>>>>
h323cucm8(config-route-map)#do sh run | sec route-map test
match ip address prefix-list test1 ! test2
Then I tested following -
Router1 -------------- Router2
Router1 :
ip route 11.0.0.0 255.255.255.0 Null0
ip route 22.0.0.0 255.255.255.0 Serial0/1.1
ip prefix-list test1 seq 5 permit 22.0.0.0/24
route-map test permit 10
router eigrp 1
redistribute static metric 1 1 1 1 1 route-map test
network 155.1.146.1 0.0.0.0
no auto-summary
Router2 :
router eigrp 1
network 155.1.146.4 0.0.0.0
no auto-summary
and on R2 I could see the all the static routes getting redistributed -
sh ip eigrp topo
IP-EIGRP Topology Table for AS(1)/ID(150.1.4.4)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 155.1.146.0/24, 1 successors, FD is 281600
        via Connected, FastEthernet0/1
P 11.0.0.0/24, 0 successors, FD is Inaccessible
        via 155.1.146.1 (2560025856/2560000256), FastEthernet0/1
P 22.0.0.0/24, 0 successors, FD is Inaccessible
and if I modify the route-map statement on Router1 as -
Then on R2 -
sh ip eigrp topo
If you are specifying multiple prefix-lists in route-map then it takes it as LOGICAL OR.
I tried to define, if it's possible to crate a prefix-list with the "!" as it's name -
h323cucm8(config)#ip prefix-list ?
  WORD             Name of a prefix list
  sequence-number  Include/exclude sequence numbers in NVGEN
h323cucm8(config)#ip prefix-list ! ?
h323cucm8(config)#ip prefix-list ! test1 ?
h323cucm8(config)#ip prefix-list ! test1 permit 10.0.0.0/24
% Invalid input detected at '^' marker.
I don't know if the behavior will vary based on the IOS used, but if IOS is throwing the parser error - then I would not use it, instead I will prefer using something like this -
h323cucm8(config)#route-map test permit 10
h323cucm8(config-route-map)#description Global subnets
h323cucm8(config-route-map)#match ip address prefix-list test1
Also I have not seen any sh command giving the outputs including the comments (starting with !)
- HTH
Rahul
milan.kulik
Level 10
Level 10
I believe your router is matching a non-existing prefix-list "eigrp-deny-global ! Global subnets".
Why don't you use a standard command
route-map EIGRP_Out deny 20
match ip address prefix-lists eigrp-deny-global
instead?
HTH,
Milan
Hi ,
Can you please share your config of prefix list and route map.It will help is better understanding of the feature.
Vinay
