Cisco 887VA-M-K9 ADSL Issue
chris.kelly.au
Hey Community,
Im a first timer at these cisco routers, and Im having a few issues with my adsl connection (or lack there of it)
Im not able to ping any outside sources from the router, and the internet clearly isnt working for my clients. Can anyone point out where im going wrong here.
Thanks its greatly appreciated in advance..
Below is my Running-config
Current configuration : 5167 bytes
! Last configuration change at 08:43:56 Sydney Wed Nov 14 2012
! NVRAM config last updated at 08:44:18 Sydney Wed Nov 14 2012
version 15.1
no service pad
hostname axiomRouter
boot-start-marker
boot-end-marker
enable secret 5 ...
enable password ...
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
memory-size iomem 10
clock timezone Sydney 10 0
clock summer-time Sydney date Mar 30 2003 3:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3310726841
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3310726841
revocation-check none
rsakeypair TP-self-signed-3310726841
crypto pki certificate chain TP-self-signed-3310726841
...removed...
ip source-route
no ip routing
no ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FGL163526MG
username admin privilege 15 secret 4 YJx95cuZ6It3C4MyUzo0OYTyoCIl6ufVYfJEpERnXlc
controller VDSL 0
interface Loopback0
no ip address
interface Ethernet0
no ip address
no ip route-cache
shutdown
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip route-cache
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
ip address 10.10.10.8 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname blank@direct.telstra.net
ppp chap password 0 blank
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat source static tcp 10.10.10.5 443 interface Dialer0 443
ip nat source static tcp 10.10.10.5 3389 interface Dialer0 3387
ip nat source static tcp 10.10.10.5 20 interface Dialer0 20
ip nat source static tcp 10.10.10.5 25 interface Dialer0 25
ip nat source static tcp 10.10.10.5 135 interface Dialer0 135
ip nat source static tcp 10.10.10.5 110 interface Dialer0 110
ip nat source static tcp 10.10.10.5 6004 interface Dialer0 6004
ip nat source static tcp 10.10.10.5 6001 interface Dialer0 6001
ip nat source static tcp 10.10.10.5 6002 interface Dialer0 6002
ip nat source static tcp 10.10.10.5 10009 interface Dialer0 10009
ip nat source static tcp 10.10.10.5 81 interface Dialer0 81
ip nat source static tcp 10.10.10.5 21 interface Dialer0 21
ip nat source static tcp 10.10.10.5 12009 interface Dialer0 12009
ip nat source static tcp 10.10.10.5 8443 interface Dialer0 8443
ip nat source static tcp 10.10.10.5 12005 interface Dialer0 12005
ip nat source static tcp 10.10.10.5 587 interface Dialer0 587
ip nat source static tcp 10.10.10.5 80 interface Dialer0 80
ip nat source static tcp 10.10.10.5 11009 interface Dialer0 11009
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
banner login ^C***** Restricted Access *****^C
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password blank
login
transport input all
end
mavespig
Level 3
Level 3
Hi Chris,
check first if DSL is up or not:
show controller vdsl
show int dia 1 -> to check if you got an IP.
If DSL layer is up and you got an IP, try to ping google from the router (try 8.8.8.8)
If the ping works, then you need to look at the NAT configuration
Hope this helps
Marco
mavespig
Level 3
Level 3
Hi Chris,
Hope this helps
Marco
