Cisco 887VA-M-K9 interfaces only work in ROMMON MODE
ITVC
I have a Cisco 887VA-M-K9, the network interfaces only work in 'rommon mode' in fact I can communicate with a TFTP server using FE / 0 only in this 'rommon' mode otherwise when the router loads the firmware from the flash with a simple and correct configuration no longer communicates with the network interfaces, they are 'UP', also the VLAN1 is 'UP' with the assigned IP there is no communication with the network, the LED blink quickly but there is no exchange of data, no ping or other.
Thank you in advance
11 Replies 11
have you tried to reset the router to factory defaults ?
https://www.hardreset99.com/routers/cisco/cisco-887va-factory-reset/
hi,
yes reset 'Reset Button pressed' executed but the situation does not change.
thanks
can you see that configuration, and can you post it ?
yes, with console port.
sample configuration on router with gateway 10..10.10.1:
Router#sh run
Building configuration...
Current configuration : 1209 bytes
! Last configuration change at 16:20:56 UTC Sat Dec 29 2018
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
license udi pid C887VAM-K9 sn XXXXXXXXXXX
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 10.10.10.2 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
yes I connected with console port, this is a simple test configuration, with gw 10.10.10.1 connected.
Router#sh run
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Router#
Hello
As you have assigned an ip address to vlan 1
Make the fastethernet ports into access ports and test again as by the looks of it they are all currently routed ports
int x/x
switchport
switchport access vlan 1
no shut
Kind Regards
Paul
Router#sh run
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Router#
Router#sh run
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Router#
to be honest I am not really clear on what the problem is. The basic configuration you would allow you only to communicate with the router from a PC connected to one of the FastEthernet ports, using an IP address from the 10.10.10.0/24 space, and with 10.10.10.2 as the default gateway. Is this working ?
We are not sure what is the device role in your network. is this router you use for DSL and you lan connected to this router to use internet. ?
in that case you need to configure the router, other vlan 1 configuration of IP you do not have rest of the configuration.
here is config guide
https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_010.pdf
BB
balaji.bandi
This looks like for me you have default configuration here..as suggestion @Georg Pauwen  --please post the current configuration to understand what is wrong?
BB
