Cisco 887VA M K9 on domestic (dynamic IP) BT ADSL
Lee.Uzi4you
Does anyone have a working config for this setup, I configured using the BT instructions but still no internet, I have tried various solutions from the forums but still no internet or ability to ping outside networks. I have in vain tried to get the latest BT firmware for the router but no joy so far.
Thanks in advance
Lee
Hello Lee
Okay then just change the dhcp pool to have your isp dns server address instead of  your router then you should be good to go.
You can remove the two virgin dns server address also is you wish.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
15 Replies 15
Lee.Uzi4you
config I have at the moment
Current configuration : 1810 bytes
! Last configuration change at 08:25:23 UTC Mon Apr 22 2013
version 15.1
no service pad
hostname Uzi
boot-start-marker
boot-end-marker
enable password ******
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp pool sdm-pool
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.9
   lease 0 2
ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FCZ1513C57J
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
description Ethernet
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.0.9 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname anything@btinternet.com
ppp chap password 0 passwd
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging esm config
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
access-list 101 permit ip 0.0.0.0 255.255.255.0 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password ********
login
transport input all
end
Hello
What dsl technology are you supposed to be using? - ADSL/VDSL etcc..
Do you get an ip address from the ISP -
sh int dialer 0
Try rebooting the adsl/vdsl modem
res
Paul
Thanks.
Kind Regards
Paul
Hi there
dsl is ADSL2 and Ip is allocated dynamically from ISP
dialer0 config
Uzi#sh int dialer0
Dialer0 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is 109.150.72.199/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:03:16
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
     7 packets input, 448 bytes
     22 packets output, 858 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 895 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer0
  Vaccess status 0x44
  Bound to ATM0.1 VCD: 1, VPI: 0, VCI: 38, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di0 (Encapsulation PPP)
  Last input 00:00:05, output never, output hang never
  Last clearing of "show interface" counters 00:01:56
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     30 packets input, 1920 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     28 packets output, 973 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Uzi#
The PPP light is now on and it looks like a get an address from my ISP
I cannot ping outside my network? and have no internet access
Could this be a NAT issue
Lee
I cannot ping from A LAN machine but I can ping eg 4.2.2.2 from the router interface
your  nat seems okay,
I see you are using subnet 0 in this ip range for dhcp,  try changing it
service dhcp
ip dhcp excluded-address 192.168.1.9
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.9
   lease 0 2
and ammend your acl,
no  access-list 101
Access-list 101 permit ip 192.168.1.0 0.0.0.255 any
interface Vlan1
ip address 192.168.1.9 255.255.255.0
res
Paul
Thanks.
Kind Regards
Paul
Hi Paul
Uzi#sh config
Using 1808 out of 262136 bytes
! Last configuration change at 09:39:39 UTC Mon Apr 29 2013
version 15.1
no service pad
hostname Uzi
boot-start-marker
boot-end-marker
enable password *********
no aaa new-model
ip source-route
   import all
   lease 0 2
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 0/38
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip http server
logging esm config
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password **********
login
transport input all
end
Ping results
Uzi#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/36 ms
Uzi#ping www.google.com
Translating "www.google.com"...domain server (255.255.255.255)
% Unrecognized host or address, or protocol not running.
Uzi#
Lee
Hello lee,
You dont say where you pinging this from, however you can add a dns server for the dhcp clinets  and for the router is you wish.
dns-server 192.168.1.9
exit
ip name-server 8.8.8.8 194.168.4.100 194.168.8.100
res
Paul
Thanks.
Kind Regards
Paul
Now were getting somewhere
ping sent from the router interface (via telnet)
Sending 5, 100-byte ICMP Echos to 173.194.34.179, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/30/32 ms
Uzi#
ping sent from local machine attached to router via ethernet cable
pinging 173.194.34.179 succeedes with 4 good replies
pinging www.google.com
Ping request could not find host www.google.com. Please check the name and try again
Hello Lee,
Did you amend you dhcp pool to included the dns server 192.168.1.9
Do an ipconfig /all on local  machine and see if they have a dns server allocated
if not
ipconfig /release
ipconfig /renew
ipconfig /registerdns
then try again
res
Paul
Kind Regards
Paul
Just to check I changed the last couple of name servers to a couple supplied by my ISP (British Telecom), exactly the same result, cannot resolve a website name but can find an IP address? puzzled!
Hello Lee
Just to confirm,  you can ping the internet from the client now  but cannot resolve the FQDN ( dns name) correct?
Have you refreshed the clients pc ip address as I suggested?
res
Paul
Thanks.
Kind Regards
Paul
build so far
Uzi#sh config
Using 1970 out of 262136 bytes
! Last configuration change at 11:44:39 UTC Mon Apr 29 2013
version 15.1
no service pad
hostname Uzi
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
   import all
   lease 0 2
ip cef
ip name-server 194.168.4.100
ip name-server 194.168.8.100
ip name-server 62.6.40.178
ip name-server 62.6.40.162
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 0/38
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip http server
logging esm config
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password ******
login
transport input all
end
tried same ping tests on another pc and same results,
have saved config, rebooted router, restarted PC's
network cards are set to get ip address automatically from DHCP (and they do get an address in the 192.168.1. range)
use DNS servers is set to automatic. (if i add a DNS server manually such as 62.6.40.178) then ping and internet work fine.
some settings collected fron network card;
dhcp server shows 192.168.1.9
default gateway  192.168.1.9
ipv4 address 192.168.1.1
windows ip configuration
host name...............uziLaptop-win8
primary dns suffix......
node type.................hybrid
ip routing enabled......no
wins proxy enabled....no
I did try the refresh dns settings as well
Lee
Hello Lee
res
Paul
Thanks.
Kind Regards
Paul
Perfect
Solved
I will post a finished running config when I get back tomorrow
