SNMP configuration issue
salman abid
Hi all,
i have some issue while adding cisco switches on solarwinds.......from my switch i can ping solarwinds server but when i put the snmp community credentials in solarwinds and test it, i'm not able to test it successfuly
snmp-configuration on switch
snmp-server community V!3w#r RO 80
snmp-server community wR!t#r RW 80
snmp-server trap-source Vlan1111
kindly find the attached snapshot of solarwind configuration
Bilal Nawaz
Hello Salman,
I see that you have an access-list 80 applied to your community strings... So only the IP's that are permitted in the ACL can access it properly.
Could you tell me what the ip address of the Solarwinds NPM - im guess its 192.6.14.196? And show us the access-list 80. You can do this like 'show ip access-list 80' - This IP should be permitted.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Hello Salman,
Hope this helps
@bilal Nawaz
thanks for the reply
yes u r right 192.6.14.196 was not permited in the ACL and i have added that in ACL
now it is working fine
