Cisco 887VA - NAT & DNS problem
MasterPrenium
Dears guys,
I'm currently having some problem while trying to correctly setup my Cisco887VA modem.
First of all I usually use netfilter with all NAT, etc ... features, but I'm quite a noob in cisco and I want to learn more.
The problem is that I want to redirect all internet traffic coming from the Internet to my Linux Gateway which will do further nat actions, filtering, etc ... (IPv4 : 192.168.3.2).
I finally got this action working, ( ip nat inside source static 192.168.3.2 interface Dialer0 ) but when I setup the nat to do this, I don't have anymore DNS working with my ISP DNS servers. Without the nat the cisco can resolve without any problem.
I would like to setup a rule which will be something like : redirect with nat all traffic coming from Internet to 192.168.3.2, but if it's the modem that request an IP with dest port = 53, then don't do the nat on this connection.
Note also that I get my IPv4 from my ISP via ipcp.
I hope this is clear.
Here is my full config :
Current configuration : 2004 bytes
! Last configuration change at 14:03:26 UTC Tue Jun 4 2013
version 15.1
no service pad
hostname Cisco887
boot-start-marker
boot-end-marker
enable secret 5 xxxx
enable password xxxx
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn xxxxx
controller VDSL 0
firmware filename flash:VA_A_35l_B_35l_23j.bin
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
shutdown
no cdp enable
interface FastEthernet1
no ip address
shutdown
no cdp enable
interface FastEthernet2
no ip address
shutdown
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
ip address 192.168.3.123 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxx
ppp chap password xxxxxx
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 12 permit 192.168.3.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
access-class 12 in
password cisco
login
transport input all
end
6 Replies 6
Int vlan 1
Ip helper-address dns_ip_address
End
Wr
Hope this helps
Alessio
No that doesn't help.
Note also that I get my dns servers from my isp by the ppp session.
Thanks.
Nat debugging :
80.10.246.7 is my ISP DNS server
86.198.231.238 is my public IPv4 address
Jun  5 16:47:04.795: NAT*: o: udp (80.10.246.7, 53) -> (86.198.231.238, 60648) [10432]
Jun  5 16:47:04.795: NAT: o: udp (80.10.246.7, 53) -> (86.198.231.238, 60648) [10432]
Jun  5 16:47:04.795: NAT (UDP-DNS): Before Translation
Jun  5 16:47:04.795: NAT: Translation of UDP DNS src 80.10.246.7, dst 86.198.231.238
Jun  5 16:47:04.795: NAT: Dns type of Response
Jun  5 16:47:04.795:    : dns len=54, id=22398, aa=0, tc=0, rd=1, ra=1
Jun  5 16:47:04.795:    : opcode=0, rcode=0, qdcount=1
Jun  5 16:47:04.795:    : ancount=1, nscount=0, arcount=1
Jun  5 16:47:04.795: Answer section:
Jun  5 16:47:04.795: Authority section:
Jun  5 16:47:04.795: Additional record section:
Jun  5 16:47:04.795: NAT (UDP-DNS): After Translation
Jun  5 16:47:04.795: NAT: s=80.10.246.7, d=86.198.231.238->192.168.3.2 [10432]
The problem is that the packet is forwarding back to 192.168.3.2 even if it's the cisco who made the DNS request.
show ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
udp 86.198.231.238:53265  192.168.3.2:53265     80.10.246.7:53        80.10.246.7:53
It should be 192.168.3.123 instead of 192.168.3.2 if I correctly understand what infos is displayed.
You have configured static translation so everything coming to your router with destination IP 86.198.231.238 will be forwarded to private IP 192.168.3.2.
You can not use one public IP for static NAT and also PAT. Delete PAT configuration from your router.
no ip nat inside source list 1 interface Dialer0 overload
Connect all host in your LAN to your Linux box and NAT them, otherwise they will not be able to reach internet.
To your problem with DNS.
After you do everything what I wrote earlier, you can choose two options how to configure DNS.
I assume that you run DHCP on your Linux box. Configure DHCP to send clients DNS IP public addresses.
Or you can use your router as DNS relay, DHCP will sent clients IP address of your router as DNS server [192.168.3.123]. But additionally you need to configure this on your router:
ip domain-lookup
ip dns server
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hello, thanks for your answer.
I did what you said (no ip nat inside source list 1 interface Dialer0 overload)
And your right, I've a dhcp server running on the Linux box, I temporaly fix the issue by using the google public DNS server, but I would prefer using my ISP (via the cisco) DNS servers.
Here is my "Internet" schema:
{Internet} <======>[Public IP Dyn. Allocated - Cisco887-  192.168.3.123]<======>[192.168.3.2 - Linux Gateway - 192.168.2.254] <=====>{One part of my network}
The LinuxBox has also some other networks connected.
Regarding the DNS problem, it still remains, I can't use the cisco router as a DNS server, neither it can access the Internet (ie : a ping to 8.8.8.8 doesn't work for example), because all packets are still forwarded to the Linux Box(192.168.3.2).
Is there a way to exclude forwarding packet in the case the connection was initialized by the Cisco ?
You are right, cisco as DNS relay will no work, all returning traffic will be forwarded to Linux box. There is nothing we can do about it.
Configure Linux box to use your ISP's DNS server in DHCP, I think that is only solution you got in your scenario.
Best Regards
That's was I was thinking about .
There is no way to setup something that is called a "DMZ" in most of the basic modem/router that can be found everywhere ?
Theses modems usually have this "DMZ" option in the config interface in which we indicate a private IP address in order to have all Internet traffic redirected to ? But theses modems are able to act as a DNS server, and ping public IPs etc ...
