EIGRP Link Cost (AD/FD Manipulation)
Ahmed3415
Hello all,
I would like to know how to calculate the link cost for EIGRP, I understand that the FD of the path to a network is calculated in some way through EIGRP metric. In a senerio (Refer to Image Attached) where the R1 is conneting to network and has 2 paths to reach the network. R1 via (5 AD to) R2 - (10 AD to) R3 - (10 AD to) R5 - (5 AD to) Netowrk, and another path is R1 via (5 AD to) R4 - (10 AD to) R5 - (5 AD to) Netowrk. So accourding to the condition on selecting feasible succesor no FS is selected as the condition is not met. So is there a way to manipulate the AD per segment on Link to Link bases in EGRP?
Thanks in Advance!
Ahmed
Hello
Do you wish to manipulate a best path over two equal paths? if so you can set the delay value on one the interfaces to eigrp will calculate a higher or lower metric for that interface - as by default eigrp calculate metric based on lowest Bw & total delay - but its safer to just manipualte the delay value of the interface rather then the BW .
interface x/x
delay xxx
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
pdriver is correct, also manipulating BW could cause other problems, as well as qos, link speed etc...
