Cisco 887VA-W Access Point booting loop cannot break to Rommon
tech_king
Guys i just got a 887vaw  and was updating the image on the access point AP802.  When i rebooted the AP it began loading fine then it crashed and began a booting cycle. Im unable to reach rommon mode. Is there anyway i can get into rommon and load the original image?
Leo Laohoo
The IOS of the AP could be corrupt.
What kind of IOS image is the AP trying to boot?  Autonomous or Controller-based?
Let's presume that it is booting autonomous IOS, the only way to fix this is to for the AP to boot in controller-based IOS and force the AP to download the autonomous IOS (and delete the old IOS image).
To force the AP to boot into controller-base IOS, the command on the router is:
config t
 service-module wlan-ap0 bootimage unified
 service-module wlan-ap 0 reload
end
This will cause the AP to boot into controller-based IOS (default password is Cisco/Cisco).
Once the AP boots into controller-based IOS do this:
enable
NOTE:  Username/Password is Cisco/Cisco
config t
int f0
 ip address <IP Address> <Subnet>
 no shutdown
end
archive download-sw /overwrite tftp://<TFTP IP address>/IOS_filename.tar
I believe I downloaded the Lightweight version but when the AP is booting up it says that its changing the ios to a autonomous version. It seems like the ios is indeed corrupt because it says that the verification check failed. the "service-module wlan-ap0 bootimage unified" command is not available. Do you know how i can fix this?
This command should be run on the router.
