CISCO 888 IOS for BGP protocol
acomito_cisco
Good morning,
while configuring a CISCO-888-EA-K9, I encountered the following problem:
Router(config)#router bgp 65000
Protocol not in this image
The router is originally equipped with the image: c800-universalk9-mz.SPA.152-4.M3.bin
I tried also: c800-universalk9-mz.SPA.153-2.T.bin
without results.
I would appreciate any cooperation in resolving this issue.
Cordially
3 Accepted Solutions
James Neilson
What license does the router have? I suspect this will be a licensing rather than IOS issue. You'll need the advanced IP services license for the router for BGP to work.
cadet alain
you'll need 15.3(2)T or higher with the Advanced IP services.
Alain
I checked the Cisco Feature Navigator and it agrees that for the 888 you need the Advanced IP Services license.
Rick
Rick
James Neilson
cadet alain
Alain
Rick
Rick
acomito_cisco
I thank you all for providing such a fast response.
I'll contact my Cisco account for the license needed..
Greetings
