I have a problems with the intervlan ( i cant access to the intern from the switch)
eramos
hi everyone , i have the follow problems
i have access from my router to the internet but from my users ( vlan 61 and vlan 60) i can reach the internet .
can you help me what is the problema please
i show you the router
interface Multilink1
no ip address
ppp multilink
ppp multilink group 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/0.62
encapsulation dot1Q 62
ip address 192.168.62.2 255.255.255.0
ip wccp 61 redirect in
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.62.2
interface GigabitEthernet0/0.63
encapsulation dot1Q 63
ip address 192.168.63.2 255.255.255.0
interface GigabitEthernet0/1
ip address 209.X.X.1 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:0
ip address 172.X.X.X 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip wccp 62 redirect in
ip flow ingress
ip flow egress
service-policy output WAN
router eigrp 100
network 172.X.X.X 0.0.0.3
network 192.168.62.0
network 192.168.63.0
network 192.168.120.0
redistribute static
ip nat inside source list ACL-NAT-SERVERS interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 209.X.X.6
ip route 192.168.17.0 255.255.255.0 192.168.1.14
ip route 192.168.24.0 255.255.255.0 192.168.63.11
ip access-list standard WR
ip access-list extended ACL-NAT-SERVERS
permit ip 192.168.60.0 0.0.0.255 any
permit ip 192.168.61.0 0.0.0.255 any
deny ip 192.168.60.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip 192.168.61.0 0.0.0.255 192.168.0.0 0.0.255.255
interface Vlan60
ip address 192.168.60.2 255.255.255.0
interface Vlan61
ip address 192.168.61.2 255.255.255.0
ip helper-address 192.168.60.10
interface Vlan63
ip address 192.168.63.11 255.255.255.0
router eigrp 100
eigrp stub connected summary
network 192.168.24.0
network 192.168.60.0
network 192.168.61.0
ip default-gateway 192.168.19.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.61.16
no ip address
ppp multilink
no ip address
shutdown
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
ip address 172.X X.X .255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
router eigrp 100
redistribute static
and my switch
interface Vlan60
interface Vlan61
interface Vlan63
router eigrp 100
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.63.2
Kelvin Willacey
Level 4
Level 4
Are you saying that users on VLAN 60 and 61 do not have access to the Internet? If so then you will require a 'ip nat inside' configured on the VLAN interfaces. Your NAT ACL and nat statement look fine to me, you should not need to use a NAT pool as Edwin suggested but you could if you wanted to.
Eddie.brown1986
Hello Edwin,
I see you have a static NAT entry with an access list enabled on it which is good. However it looks like you didn't specify a pool to use with that static NAT entry. Try this:
ip nat pool EDWIN 209.x.x.1 209.x.x.1 prefix-length 30
ip nat inside source list ACL-NAT-SERVERS pool EDWIN overload
Let me know how it goes.
Eddie
thank you for your help
Kelvin Willacey
Level 4
Level 4
awsome thank you .
