Cisco 891 Fail over Configuration
andyspranata
Cisco 891 configuration Details:
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname XXXXX
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 YYYYYYYYYYYYYYYYYYYYYYYYYY
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no ip source-route
ip dhcp pool ccp-pool1
   import all
   network 10.153.64.0 255.255.255.128
   default-router 10.153.64.1
   dns-server 8.8.8.8
   lease infinite
ip cef
no ip bootp server
ip domain name VVVVVVVVVVVV
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 10.153.65.1
ip name-server 10.153.66.1
ip inspect tcp reassembly queue length 128
no ipv6 cef
track 1 ip sla 1 reachability
delay down 9 up 10
track 2 ip sla 2 reachability
delay down 9 up 10
interface FastEthernet8
description $ETH-WAN$$FW_OUTSIDE$
ip address 10.153.66.5 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address 10.153.65.5 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
interface Vlan1
description LAN Connection$ES_LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 1$$FW_INSIDE$
ip address 10.153.64.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map A interface FastEthernet8 overload
ip nat inside source route-map B interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 10.153.65.1 track 1
ip route 0.0.0.0 0.0.0.0 10.153.66.1 100 track 2
ip sla 1
icmp-echo 10.153.65.1 source-interface GigabitEthernet0
threshold 2
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.153.66.1 source-interface FastEthernet8
frequency 5
ip sla schedule 2 life forever start-time now
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.153.64.0 0.0.0.127
access-list 10 permit 10.153.64.0
access-list 110 permit ip 10.153.64.0 0.0.0.127 any
no cdp run
route-map A permit 10
match ip address 110
match interface GigabitEthernet0
route-map B permit 10
match interface FastEthernet8
I could connect to the Gigabitethernet wan, based on above configuration.
When I test on FastEthernet8 for the secondary ISP connection it will not go through the internet.
The Ping details
ping from (10.153.65.5) to 8.8.8.8 = OK
ping from (10.153.66.5) to 10.153.66.1 = OK
ping from (10.153.66.5) to 8.8.8.8 = not OK
PLease advice?
17 Replies 17
Hi Andy,
        Yes you can.
Edit: Your configuration looks fine to me. It's Active/Standby.
You can use PBR to redirect a host to WAN(FastEthernet)
ip access-list ext Redirect-Host
permit ip host 10.153.64.61 any
route-map GoToFastEthernet permit 10
match ip address Redirect-Host
set ip next-hop 10.153.66.1
int vlan 1
ip policy route-map GoToFastEthernet
HTH,
Toshi
Hello Thotsaphon Lueangwattanaphong,
You are a genius.
I should take the CCNA course soon to become like you.
Thank you very much.
Andy
Andy,
      Go get it
I'm glad that I could help
Toshi
