Cisco 891f speed internet too slow
CVSz
what wrong ?
Building configuration...
Current configuration : 2531 bytes
! Last configuration change at 08:38:27 UTC Wed Dec 25 2019
version 15.3
hostname Cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
enable secret 5 xxxxx
enable password xxxx
no aaa new-model
ip dhcp excluded-address 192.168.2.1 192.168.2.30
ip dhcp pool vlan1pool
 import all
 network 192.168.2.0 255.255.255.0
 dns-server 192.168.1.1 8.8.8.8 8.8.4.4
 default-router 192.168.1.1
 lease 0 2
no ip domain lookup nsap
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FGL224510VM
no spanning-tree vlan 1
spanning-tree vlan 1 priority 8192
ip ftp username xxxx
ip ftp password xxxx
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 no ip address
 spanning-tree portfast
interface GigabitEthernet1
 no ip address
 shutdown
interface GigabitEthernet2
 no ip address
 shutdown
interface GigabitEthernet3
 no ip address
 shutdown
interface GigabitEthernet4
 no ip address
 shutdown
interface GigabitEthernet5
 no ip address
 shutdown
interface GigabitEthernet6
 no ip address
 shutdown
interface GigabitEthernet7
 no ip address
 shutdown
interface GigabitEthernet8
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface Async3
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool vlan1pool 192.168.2.21 192.168.2.240 netmask 255.255.255.0
ip nat inside source list 1 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp-server community public RO
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 3
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 password xxxxxxx
 login
 transport input all
scheduler allocate 20000 1000
end
a few things look odd in your configuration. Make the changes/additions marked in bold and see if that makes a difference:
version 15.3
hostname PoliceLMS
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
no aaa new-model
import all
dns-server 8.8.8.8 8.8.4.4
lease 0 2
ip cef
no ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address dhcp
ip nat outside
--> no ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
--> no ip nat pool vlan1pool 192.168.2.21 192.168.2.240 netmask 255.255.255.0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
--> no ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
password 8owmpiyddyo
login
transport input all
end
version 15.3
hostname PoliceLMS
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
no aaa new-model
import all
lease 0 2
ip cef
no ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
login
transport input all
end
i don't know why now can't connect can you help me please
Cisco#show run
Current configuration : 2386 bytes
version 15.3
hostname Cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
enable secret 5 xxxxxxxxxx
enable password xxxxxxxxxx
no aaa new-model
 import all
 lease 0 2
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
ip ftp password xxxxx
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 ip nat inside
interface Async3
 no ip address
 encapsulation slip
no ip http server
ip dns server
control-plane
line con 0
 no modem enable
line aux 0
line 3
 modem InOut
 speed 115200
line vty 0 4
 password xxxxxxxxxx
 login
 transport input all
end
make the changes marked in bold:
version 15.3
hostname Cisco
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
no aaa new-model
import all
default-router 192.168.2.1
lease 0 2
ip cef
no ipv6 cef
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
ip dns server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
password xxxxxxxxxx
login
transport input all
end
