Cisco 892 Problem Configuring PPPoE
mukesh.surya
Hello Guys,
I need your help.
I've got a Cisco 892 Router in which I'm trying to configure PPPoE connection. I'm not a pro, I've tried commands which I founded on the internet but it didn't work. I've reset the router. Please help me out.
Thanks.
here is a generic sample for the PPPoE part. Post the configuration you currently have, also indicate who your ISP is:
interface GigabitEthernet0
description ISP_UPLINK
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
no shutdown
interface Dialer1
description DIALER_TO_ISP
ip address negotiated
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
load-interval 30
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname yourhostname
ppp chap password yourpassword
ppp pap sent-username yourhostname password yourpassword
Deepak Kumar
Your configuration will like:
interface Dialer1
description $PPOE Dailer$
mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
ppp authentication chap pap ms-chap callin
ppp chap hostname <ISP Username>
ppp chap password <ISP password>
ppp pap sent-username <ISP Username> password 0 <ISP password>
interface FastEthernet0
description WAN-PORT-PPOE-CONNECTED
no ip address
pppoe enable group global
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
