03-16-2019 02:52 PM
whenever i refresh or stop&start live captures im getting below error
Please help anyone on this wireshark issue with GNS3
please find the attached photo
Thanks in advance.
Solved! Go to Solution.
03-16-2019 03:28 PM
This is more of GNS3 issue, suggest to post this on GNS3 Forum, so iam sure some developper able to address your issue.
03-16-2019 02:58 PM
I could capture the packet with GNS3 in the first time of run capture, if i restart or stop & start the live capture im getting bellow Error,
""Data written to the Pipe is neither in a supported pcap format nor in pcapng format. please report this to the developers of the program writing to the pipe.""
Also If i close and reopen GNS3 and wireshark im able to capture the packet, that's too only one time as i mentioned if i stop the capture in GNS3 i couldn't run capture again ,
so the option for me to work with wireshark is :
*I should not stop the capture once i turned on ( its very hard to do searching and examining packets without refresh )
*I should close and reopen the entire GNS3 and wireshark application once I stopped the capture (its similar to start work freshly , this process takes too much time )
please help someone it would be very helpful for me.
03-16-2019 03:28 PM
03-16-2019 02:59 PM - edited 03-16-2019 03:00 PM
