CISCO 892 ROUTER NOT HANDING OUT
cigalahgroup
Hello I have  very simple configuration on cisco 892 k9 router to run dhcp configuration, but sadly its not working i did trying restart the service but didn't worked. please check the  configurations.
Router#sh run
Building configuration...
Current configuration : 1601 bytes
! Last configuration change at 03:49:05 UTC Thu Feb 7 2036
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.0.1
ip dhcp pool skak
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FCZ174993FU
redundancy
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input none
end
Router#
Router#
Router#
Router#
Router#
Router#
Router#sh ip dhcp bin
Router#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
Router#
Hardware address/
16 Replies 16
Hello @cigalahgroup ,
from the info provided, it seems that you are using interface Ethernet 7 to connect to your switched network, but this interface seems to be a Layer 3 interface.
Try adding the following commands on interface Ethernet 7:
switchport
switchport access vlan 1
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
i did doesn't works
What is the configuration of the switch interface the router is connecting to?
Regards, LG
There is no switch i am directly connected to the laptop. if i give manual ip to the router its working perfectly and pinging the router.
@cigalahgroup
If you configure a static IP address on the PC, can you ping 193.168.0.1 ?
i did static ip on the laptop interface and tried pinging the router vlan1 192.168.10.1 and its pinging.
cigalahgroup
Followed the complete guide and same issue
Router#sh run
Current configuration : 1614 bytes
! Last configuration change at 06:02:19 UTC Thu Feb 7 2036
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.10.2
ip dhcp pool skak
 import all
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.1
 dns-server 192.168.10.2
ip domain name cisco.com
ip name-server 192.168.10.2
no ipv6 cef
redundancy
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 switchport access vlan 2
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan2
 ip address 192.168.10.1 255.255.255.0
interface Vlan3
 no ip address
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
end
Your interface Ethernet 7 still has the no ip address command on it, which indicates that it's a Layer 3 interface.
Once you configure the switchport command on it, you will be able to leverage the Vlan 1 interface configured on the router and your config will work.
Regards, LG
Can I see the "show license" command output?
cigalahgroup
my bad i have changed the port to check if I have issues over the port. Hence the new port is on fastethernet 0
cigalahgroup
Still the problem presist no change at all.
@cigalahgroup
 The configuration is fine. The only thing I can think of is license.  Can you share the show license command please?
cigalahgroup
Router>
Router>
Router>
Router>en
Router#show license
Router#show license
Index 1 Feature: advipservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: ios-ips-update
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: SSL_VPN
License Count: 0/0 (In-use/Violation)
Index 4 Feature: WAAS_Express
