Cisco 892 series router limitation
nihit-tandon
Team,
I got to know that out of two  routed ports one port is only active at a time   is this a limitation on cisco 892 series router If yes  why is this so.
Kindly help me in understanding this.
nihit tandon
paolo bevilacqua
Where have you read that?
On the router !!!
I do not see any explicit note about it for the 890 routers, it is actually mentioned only for 860 (see Note in the document):
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/hardware/installation/guide/1Overview880-860.html#wp1203606
And datasheet for 890 models says they can be used for balancing, meaning you should be able to use both:
Integrated Gigabit Ethernet, SFP, and Fast Ethernet WAN ports
•  Integrated ports offer flexibility in Ethernet WAN access, and the  additional capability to deploy redundant WAN connections for failover  protections and load balancing.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
