Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 892W router HA
hkvt012345
Hi all,
i knew that new ISO for Cisco 892w can do the HA pair.
I would like to ask if i got one router 892w which only use  for connect 3 cisco aironet AP, as i do have another same model router.
Can i do the HA? as one router broken, another one will pick up .?what i need to do is just unplug the AP connect to the another standby router when it failure?
paolo bevilacqua
Wrong forum, post in "WAN and routing". You can move your post using the actions panel on the right.
