Cisco 897 as "bridge" device over aal5mux?
starbuck
I've seen a few older posts about people making this work quite well where the 800 series is simply acting as a modem and then the ASA / firewall that is sitting behind it can do the PPPOE dialing.
So this is my situation and I'm just totally stumped...I've got a Meraki MX64 that I want to use it's 2nd internet port for load balancing / failover to our ADSL which uses ATM (so PPPOA).  I don't want to do any kind of double-nat setup and want the Meraki to be able to dial and get an IP address. The other configs that have worked for everyone all use aal5snap encapsulation, but I get no action using that and when I look at my current ADSL modem on this connection I can see that when it's up and running its using pvc 0/100 and VCMUX for encapsulation.
I'm not quite sure how to make this work? I tried using:
encapsulation aal5mux pppoe group global
As soon as I set that, I start getting hit with the following error as the Meraki tries to PPPOE dial out
Oct 29 00:04:59.783: %TBRIDGE-4-NOVCFLOOD: No VC's configured for bridging on ATM0.1
If I set encapsulation as aal5snap, the MX64 can't dial out it seems, but I also don't get any errors either.
Here's my current config:
Building configuration...
Current configuration : 1548 bytes
! Last configuration change at 00:34:05 UTC Mon Oct 29 2018
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn FGL182923FZ
vtp mode transparent
controller VDSL 0
vlan 11
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
bridge-group 11
pvc 0/100
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
switchport access vlan 11
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan11
no ip address
bridge-group 11
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 11 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Fotiosmark
So
You have an 800 and a Meraki and you want to connect Meraki directly to the DSL line? or Behind the 800 ? I didn't really udnerstand what you are trying to do.
The MX64 sits behind the 800 because it doesn't have ADSL capabilities. So the 800 acts as the modem and the MX64 initiates the PPPOE and get's a public IP address
