Cisco 897 VAW - Reset to default settings
sonic2323
I have a Cisco 897VAW that I bought from someone. Does anyone know how I can delete everything and restore it to factory settings? I have tried pressing the reset button in the back but it keeps booting up to the same config, I do not have access to the router because the old password is still set. I have googled more info on this but there is not much out there that i could find. Any help would be appreciated. I tried hitting pause break to get into rommon but nothing. Im at a loss.
InayathUlla Sharieff
https://www.scribd.com/doc/121854767/Router-cisco-860-series
Go to reset procedure and follow the same.
Inayath
