Cisco 897VAG-LTE series router, can it be setup on FTTP NBN?
VULCA
Hello all! First time poster and newbie to networking here.
As a personal project and achievement I am hoping to get this 897 series router setup as my home network router as an upgrade from my stock rubbish iinet one.
I am led to believe it is possible with this router, I am just unsure as the cisco CLI is not something I have used before.
Can any experienced veterans help a lad out?
I am not really sure where to start in terms of deploying this thing. My networking teacher at TaFE (im a cert III student currently)  says that Cisco routers are a powerful tool to wield if you know how to use them correctly, especially on a trashy little home network.
Any pointers or insight would be greatly appreciated!
31 Replies 31
Hey,
ISP is AussieBB.
do you have the config (sh run) ?
version 15.6
hostname AussieBB
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
interface GigabitEthernet8
ip address dhcp
ip nat outside
interface Vlan1
ip nat inside
ip nat inside source list 1 interface GigabitEthernet8
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C897VAG-LTE-LA-K9 sn
redundancy
controller VDSL 0
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0
description 4G Backup
ip address negotiated
ip mtu 1358
encapsulation slip
ip tcp adjust-mss 1318
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
description TBB NXXXXXXXR – XXX.XXX.XXX.XXX
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
ip tcp adjust-mss 1460
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
AussieBB is different to what OP has, in that case you just want DHCP on the WAN ie IPoE. That should a bit like my NAT example for the C1117. See the ATM interface and Ethernet0/2/0 configuration. That works with IPv6 and includes an ACL to block incoming ports.
Their ISP is iiNet they use a PPPoE interface on VLAN 2 , same as Internode which is also owned by TPG. I am thinking an example such as this one, is what you might want. (Except not VLAN 100).
This particular modem does work on the NBN but you need to update the VDSL firmware. You want to make sure you upgrade your firmware so that it supports SOS/ROC etc.
Hello
As you are using FTTN I would assume the ISP has provided you with some kind of routing device which would then enable you to attach your own rtr to?
However before you do this, Are you able to directly attach your pc to that ISP supplied routing device and if so can you access the internet from thereon in, If so remove your pc and then attach your own cisco router via its GE WAN port and post the following:
conf t
default interface GigabitEthernet X
interface iGigabitEthernet X
no shut
ip address dhcp
exit
sh ip interface brief
sh ip route
Kind Regards
Paul
AussieBB#sh ip interface brief
ATM0 unassigned YES NVRAM administratively down down
Cellular0 unassigned YES NVRAM up up
Cellular1 unassigned YES unset down down
Ethernet0 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES unset down down
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet2 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 unassigned YES unset down down
GigabitEthernet5 unassigned YES unset down down
GigabitEthernet6 unassigned YES unset down down
GigabitEthernet7 unassigned YES unset down down
GigabitEthernet8 192.168.0.181 YES DHCP up up
NVI0 21.21.21.1 YES unset up up
Vlan1 unassigned YES unset down down
AussieBB#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.0.1, GigabitEthernet8
[1/0] via 10.0.0.1, GigabitEthernet8
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet8
L 192.168.0.181/32 is directly connected, GigabitEthernet8
I'm able to plug any vdsl modem in and it connects so no issues there.  Just hoping to get the rest of the code sorted
FTTN in Australia customer has to supply hardware. All other connection types, FTTC, FTTP etc have a NTD. FTTC you should use the NBNCo NTD provided as it powers the DPU.
If you're on plain FTTN ie and the only thing in your house is a TO (Telecommunications Outlet), then you supply the hardware for this connection. There is no need for a static route in NAT mode. All that will be provided by DHCP.
This should be connected directly to the phone line, and not through any other device. As @leontunnie is with ABB they will use a simple IPoE configuration, with no settings, so that means no Dialer0, no PPPoE. Just simple ethernet config and NAT.
Does show controller vdsl 0  produce a showtime? If it does, all you need is some NAT rules:
That means on the external interface you'll need a rule like "ip nat outside" on the LAN side you'll need "ip nat inside".
Create the access list that allows the VLAN to be NATTed
access-list 1 remark INSIDE_IF=Vlan1
Then you'll want to create an overload rule. The external interface should be "Ethernet0"
ip nat inside source list 1 interface {{ YOUR EXTERNAL INTERFACE }} overload
If you want to port forward to a particular host on your network, ie say BitTorrent then this should do:
ip nat inside source static tcp 192.168.1.{{your IP}} {{port}} interface Ethernet0 {{port}}
Create your VLAN1
interface Vlan1
description Local Area Network
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip tcp adjust-mss 1412
This modem certainly does work with NBNCo and was sold for a time by Internode and Telstra. The above config is what I've seen on whirlpool.net.au and what I used with my 887 before the NVRAM failed
AussieBB#sh run
Building configuration...
Current configuration : 5100 bytes
version 15.6
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime show-timezone year
service timestamps log datetime localtime show-timezone year
service password-encryption
service sequence-numbers
hostname AussieBB
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
clock timezone utc 10 0
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool lanpool
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 8.8.8.8 8.8.4.4
lease 7
ip name-server 202.142.142.142
ip name-server 202.142.142.242
ip inspect name FWv4 tcp router-traffic
ip inspect name FWv4 udp router-traffic
ip inspect name FWv4 icmp
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 60 "OK"
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
username admin privilege 15 password 7
redundancy
controller VDSL 0
operating mode vdsl2
no cdp run
track 1 ip sla 1 reachability
policy-map shape-outbound
class class-default
shape average 39500000
interface ATM0
no ip address
shutdown
interface Cellular0
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
backup delay 0 10
backup interface Cellular0
ip address dhcp
duplex auto
speed auto
no cdp enable
interface Vlan1
ip address 10.0.0.1 255.255.255.0
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1452
ip http server
ip tftp source-interface Vlan1
ip nat inside source route-map BACKUP interface Cellular0 overload
ip nat inside source route-map PRIMARY interface GigabitEthernet8 overload
ip access-list extended INTERNET-IN
deny ip 0.0.0.0 0.255.255.255 any
deny ip 10.0.0.0 0.255.255.255 any
deny ip 127.0.0.0 0.255.255.255 any
deny ip 169.254.0.0 0.0.255.255 any
deny ip 172.16.0.0 0.15.255.255 any
deny ip 192.168.0.0 0.0.255.255 any
deny ip 198.18.0.0 0.0.255.255 any
deny ip 224.0.0.0 31.255.255.255 any
deny tcp any any fragments
deny udp any any fragments
deny icmp any any fragments
deny ip any any ttl range 0 1
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit icmp any any packet-too-big
permit udp any any eq bootpc
deny ip any any
ip access-list extended SSH-IN
permit tcp 192.168.0.0 0.0.255.255 any eq 22
permit tcp 172.16.0.0 0.15.255.255 any eq 22
permit tcp 10.0.0.0 0.255.255.255 any eq 22
deny ip any any
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet8
frequency 10000
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
route-map BACKUP permit 1
match ip address 1
match interface Cellular0
route-map PRIMARY permit 1
match ip address 1
match interface GigabitEthernet8
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit any
control-plane
vstack
line con 0
no modem enable
line aux 0
line 2
no exec
stopbits 1
line 3
exec-timeout 0 0
script dialer lte
modem InOut
no exec
line 8
no exec
line vty 0 4
access-class SSH-IN in
exec-timeout 30 0
logging synchronous
transport input ssh
ntp server 202.89.184.139
ntp server 203.206.171.84
ntp server 220.233.200.157
end
AussieBB#
I haven't followed the entire thread, so I hope I am not suggesting anything redundant, but as far as I recall, you need the 'wan mode ethernet' command in your config as well...
Hello
So you DO have isp connection via 192.168.0.181 how ever it seem you ALSO have static default which is incorrect. Once that is removed you should at least connect to the internet from the rtr.
After you have confirmed this is okay we can move forward to providing you with internet access for you internet users
Kind Regards
Paul
Mate i'm honestly struggling to see why there would be a static route in there..... Any tips?
Ive done some digging and managed to get the following:
GigabitEthernet8 192.168.3.10 YES DHCP up up
Vlan1 10.0.0.1 YES NVRAM down down
AussieBB#
AussieBB#
AussieBB#
AussieBB#
Gateway of last resort is 192.168.3.1 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected
192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.3.0/24 is directly connected, GigabitEthernet8
L 192.168.3.10/32 is directly connected, GigabitEthernet8
Does this help?
jbrown129
I'm not sure this is correct. GigabitEthernet8 is an internal interface, I think that should be Ethernet0. Does "show controller vdsl 0" show that the link is trained?
