Cisco 897VAW-E-K9 No VPN capability
woter1832
It appears that I have either bought the wrong product or there is an issue. I ipsec command are not available and in CCP, I get an error that the feature is not installed or licensed when I click on any type of VPN.
According to https://supportforums.cisco.com/discussion/9923001/871-difference-between-advipservices-and-advsecurity-ios I have the wrong license. The router is running advipservices_npe and I need advsecurity for VPN functionality.
How does one "change" the license to enable the VPN features?
An output of show license:
C897VAW#sh license
Index 1 Feature: advipservices_npe
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: advsecurity_npe
Index 3 Feature: ios-ips-update
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: MEM-8XX-512U1GB
Index 5 Feature: WAAS_Express
Many thanks
W.
michael o'nan
Level 4
Level 4
You could try
conf t
license boot level advsecurity_npe
then possibly
license accept end user agreement
Save the config and you will be required to perform a restart.
