06-18-2019 09:14 PM
Hello, I have a problem with Cisco ASR-920-24SZ-IM, when I plugged the power cord to the router, the console shows up in this mode, which has only a few commands.
I tried to boot the system, but the result is as in the following pictures
I have tried many ways from the internet, but the problem is not solved.
Can someone tell me the solution, please?
Thanks in advance
06-19-2019 12:47 AM
the line:
cannot determine first file name on device "bootflash:/"
could mean that there is something wrong with whatever file is in bootflash. Can you break into ROMMON and do a 'dir:bootflash' ?
06-21-2019 10:10 AM
Hello, Georg Pauwen
I tried to break into ROMMON, but I can do 'dir bootflash:' and I saw the file list.
I followed the solution from Cisco Community, try to boot ASR-920 .bin file but the result I got the message 'SHA-1 hash doesn't match'.
I have searched for information and I think it's is the iOS, according to this link: https://community.cisco.com/t5/routing/upgrade-rommon-from-rommon/td-p/2576096 .
Now, the router has been moved to another room. It's not my work anymore.
Thank you for your reply.
