Need Help Configuring ASA 5508-X w/ FTD
shoong001
Hi All,
Recently purchased an ASA 5508-X w/ FTD. I'm trying to configure a flat network for it, but it seems to not be able to route out. I created the route rule and set the gateway in the WEB GUI but it doesn't seem like it'll stick? Here's a clean file of "show running-config". All i'm trying to do is to set it up so that it hands out 192.168.1.0/24 and have that interface be able to access the management portal as well.
 Serial Number: JAD23160E7E
: Hardware:   ASA5508, 8192 MB RAM, CPU Atom C2000 series 2000 MHz, 1 CPU (8 cores)
NGFW Version 6.2.3
hostname firepower
enable password
strong-encryption-disable
names
interface GigabitEthernet1/1
 nameif outside
 cts manual
  propagate sgt preserve-untag
  policy static sgt disabled trusted
 security-level 0
 ip address dhcp setroute
 ipv6 address autoconfig
 ipv6 enable
interface GigabitEthernet1/2
 nameif inside
 cts manual
 security-level 0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 nameif diagnostic
 cts manual
 security-level 0
 no ip address
boot system disk0:/os.img
ftp mode passive
ngips conn-match vlan-id
object network AIM_SERVERS-64.12.31.136
 host 64.12.31.136
object network AIM_SERVERS-64.12.46.140
 host 64.12.46.140
object network AIM_SERVERS-64.12.186.85
 host 64.12.186.85
object network AIM_SERVERS-205.188.1.132
 host 205.188.1.132
object network AIM_SERVERS-205.188.11.228
 host 205.188.11.228
object network AIM_SERVERS-205.188.11.253
 host 205.188.11.253
object network AIM_SERVERS-205.188.11.254
 host 205.188.11.254
object network AIM_SERVERS-205.188.210.203
 host 205.188.210.203
object network AIM_SERVERS-64.12.24.0-23
 subnet 64.12.24.0 255.255.254.0
object network AIM_SERVERS-64.12.28.0-23
 subnet 64.12.28.0 255.255.254.0
object network AIM_SERVERS-64.12.161.0-24
 subnet 64.12.161.0 255.255.255.0
object network AIM_SERVERS-64.12.163.0-24
 subnet 64.12.163.0 255.255.255.0
object network AIM_SERVERS-64.12.200.0-24
 subnet 64.12.200.0 255.255.255.0
object network AIM_SERVERS-205.188.3.0-24
 subnet 205.188.3.0 255.255.255.0
object network AIM_SERVERS-205.188.5.0-24
 subnet 205.188.5.0 255.255.255.0
object network AIM_SERVERS-205.188.7.0-24
 subnet 205.188.7.0 255.255.255.0
object network AIM_SERVERS-205.188.9.0-24
 subnet 205.188.9.0 255.255.255.0
object network AIM_SERVERS-205.188.153.0-24
 subnet 205.188.153.0 255.255.255.0
object network AIM_SERVERS-205.188.179.0-24
 subnet 205.188.179.0 255.255.255.0
object network AIM_SERVERS-205.188.248.0-24
 subnet 205.188.248.0 255.255.255.0
object network any-ipv4
 subnet 0.0.0.0 0.0.0.0
object network any-ipv6
 subnet ::/0
object-group network AIM_SERVERS
 network-object object AIM_SERVERS-64.12.46.140
 network-object object AIM_SERVERS-205.188.3.0-24
 network-object object AIM_SERVERS-64.12.28.0-23
 network-object object AIM_SERVERS-64.12.31.136
 network-object object AIM_SERVERS-205.188.5.0-24
 network-object object AIM_SERVERS-205.188.153.0-24
 network-object object AIM_SERVERS-205.188.1.132
 network-object object AIM_SERVERS-205.188.7.0-24
 network-object object AIM_SERVERS-64.12.200.0-24
 network-object object AIM_SERVERS-205.188.11.254
 network-object object AIM_SERVERS-205.188.11.253
 network-object object AIM_SERVERS-64.12.24.0-23
 network-object object AIM_SERVERS-205.188.248.0-24
 network-object object AIM_SERVERS-64.12.186.85
 network-object object AIM_SERVERS-64.12.161.0-24
 network-object object AIM_SERVERS-205.188.11.228
 network-object object AIM_SERVERS-205.188.179.0-24
 network-object object AIM_SERVERS-205.188.9.0-24
 network-object object AIM_SERVERS-205.188.210.203
 network-object object AIM_SERVERS-64.12.163.0-24
access-list NGFW_ONBOX_ACL remark rule-id 268435457: ACCESS POLICY: NGFW_Access_Polic
y
access-list NGFW_ONBOX_ACL remark rule-id 268435457: L5 RULE: Inside_Outside_Rule
access-list NGFW_ONBOX_ACL advanced trust ip ifc inside any ifc outside any rule-id 2
68435457 event-log both
access-list NGFW_ONBOX_ACL remark rule-id 1: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 1: L5 RULE: DefaultActionRule
access-list NGFW_ONBOX_ACL advanced deny ip any any rule-id 1
pager lines 24
logging timestamp
mtu outside 1500
mtu inside 1500
mtu diagnostic 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (any,outside) source dynamic any-ipv4 interface
access-group NGFW_ONBOX_ACL global
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http ::/0 inside
http 0.0.0.0 0.0.0.0 inside
ip-client diagnostic
ip-client diagnostic ipv6
ip-client outside
ip-client outside ipv6
ip-client inside
ip-client inside ipv6
no snmp-server location
no snmp-server contact
sysopt connection tcpmss 0
no service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
crypto ikev2 policy 100
 encryption des
 integrity sha
 group 5
 prf sha
 lifetime seconds 86400
crypto ikev1 policy 160
 authentication pre-share
 encryption des
 hash sha
 group 5
 lifetime 86400
telnet timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCESer
vice
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
snort preserve-connection
Cryptochecksum:6735856a429bc55140c3326ace634758
: end
10 Replies 10
It looks like the security level on the outside and the inside interface is set to 0. Try and set the security level on the inside interface to 100...
do you know where i would be able to find that? i just clicked thru everything an unable to see where i can set the security level.
Hello Shoong001,
Georg is right by default two interfaces with same security level are not allowed to communicate.
via CLI
you just need to connect via SSH
when you get the enabled prompt
issue
config t
int gi1/2
security-level 100
end
Hope to help
Giuseppe
It looks like you are running FTD software. If that is the case then there is no concept of Security Levels as there are in ASA software. All interfaces have security level 0.
  • same-security-traffic is not applicable on FTD. Traffic between FTD interfaces (inter) and (intra) is allowed by default
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/200908-configuring-firepower-threat-defense-int.html
Are you getting a default route from the ISP via DHCP?
Hello Grant,
thanks for your correction and update
the same security-level is not an issue with FTD as you have noted.
Nice to learn something new.
Best Regards
Giuseppe
Static. When I change it to DHCP, I still get the same error.
What currently works / doesn't work?
My understanding is:
You are trying to have your Inside hosts get dhcp from the firewall? - Does this part work?
You are then trying to have those hosts get out to Internet? - This is not working?
What are the hosts using for DNS btw?
how exactly are you adding the default route ? Just be sure to follow the procedure below...
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp4100/firepower-4100-gsg/ftd_fmc_deploy.html#task_vsf_4t3_zgb
I had a distinct feeling that changing the security levels was too easy...:(
Thanks from me also for the correction...learned something useful...
@Georg Pauwen  @Giuseppe Larosa
Nothing compared to what I have learned and still learning from you both over the years on CSC 🙂, so thank you.
