CISCO 9300L - MULTICAST ROUTING
Oleksandr Y.
Hello all, been a couple of days in total since I started to investigate Multicast Routing on the 9300 CISCO Catalyst (Gibraltar V.16.12.02) Have been looking around on forums and seems like my application is a little bit too specific, not a common scenario and behavior wise seems like is not working at all. I would like to present this simple scenario that I would like to get working first and then I might be able to expand on the topic a little bit more and see if there are any solutions for that.
SIMPLE SCENARIO Drawing
From left to right, I am generating Traffic using IPERF2 that arrives on SW Interface Gi1/0/36 (can be seen incrementing in the Multicast counters) unfortunately I don't see any MULTICAST traffic in the stats of VLAN 40. Ultimate goal would be to be able to funnel this traffic over to the MODULATOR on the right side of the drawing.
Interface VLAN 40 has "ip pim dense-mode" enabled and interface VLAN 254 has "ip pim dense-mode" as well in addition to "ip igmp static-group" with the required multicast IP address.
I have tried ip igmp snooping = on/off, did not make a difference. The is got to be a simple explanation to this, and please don't refer me to https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/ip_mcast_rtng/b_166_ip_mcast_rtng_9300_cg.pdf I have gone through this booklet and I could not find any useful info or restrictions ... great book but did not help in this particular scenario.
In addition, this scenario gets a little bit more complicated in a real deployment / application ... I am using the same CISCO 9300 to send traffic to a PEP server, which then comes back to the 9300 and I am using PBR to direct traffic to the modulator ... I am not even sure how that will be handled just yet, but before I get there I need to solve this Physical to VLAN Interface mystery - if someone has any ideas please
NOTE: I am also using HSRP on VLAN 40, for that I have included the "IP PIM REDUNDANCY ..." which I am not entirely sure helps in any way at this stage at least
Any ideas will be very much appreciated
9 Replies 9
Giuseppe Larosa
Hello @Oleksandr Y. ,
two questions first :
a) what is the multicast address you are using with IPERF2 traffic simulator?
be aware that multicast addresses of type 224.0.0.X  are link local and not routable by definition . You need to use something like 224.10.20.30 as your multicast group
b) TTL :  generated traffic is still IP traffic and need to have a TTL > 1 to be able to reach the intended destination as the switch will decrease TTL.
Hope to help
Giuseppe
for some reason was not allowing me to post, and after multiple "reply" attempts was flagged as flood post :s here is a screenshot :
ok group and TTL are fine
on catalyst 9300
post
show ip mroute 239.192.12.1
you should see two entries
(*, 239.192.12.1)   this is the sparse shared tree mode
and one for
(10.10.40.50, 239.192.12.1) where the source is your IPERF2 simulator
the OLIST should contain VLAN 254 ( for the static igmp join you did )
Hope to help
Giuseppe
HI Giuseppe, here are some more details on the CONFIG of the two Interfaces and some outputs:
I have also added the MFIB Count output at the end
CORE-TRF-DSTRO-SW1-P#sh run int vlan 40
Building configuration...
Current configuration : 336 bytes
interface Vlan40
ip address 10.10.40.2 255.255.255.0
ip pim redundancy HSRP40 hsrp dr-priority 110
ip pim dense-mode
standby 40 ip 10.10.40.1
standby 40 timers 1 3
standby 40 priority 110
standby 40 preempt
standby 40 name HSRP40
load-interval 30
end
CORE-TRF-DSTRO-SW1-P#sh run int vlan 254
Current configuration : 315 bytes
interface Vlan254
ip address 192.168.254.2 255.255.255.0
ip pim dense-mode
standby 254 ip 192.168.254.1
standby 254 timers 1 3
standby 254 priority 110
standby 254 preempt
ip igmp static-group 239.192.12.1
ip policy route-map From-RLSS
end
CORE-TRF-DSTRO-SW1-P#sh ip mroute 239.192.12.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector, p - PIM Joins on route,
x - VxLAN group, c - PFP-SA cache created entry,
* - determined by Assert
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.192.12.1), 00:32:20/stopped, RP 0.0.0.0, flags: DC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan254, Forward/Dense, 00:28:07/stopped
Vlan40, Forward/Dense, 00:32:20/stopped
CORE-TRF-DSTRO-SW1-P#sh ip mroute 239.192.12.1 count
Use "show ip mfib count" to get better response time for a large number of mroutes.
IP Multicast Statistics
7 routes using 6840 bytes of memory
6 groups, 0.16 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 239.192.12.1, Source count: 0, Packets forwarded: 0, Packets received: 0
CORE-TRF-DSTRO-SW1-P#sh ip mfib 239.192.12.1 count
Default
13 routes, 10 (*,G)s, 2 (*,G/m)s
Group: 239.192.12.1
RP-tree,
SW Forwarding: 0/0/0/0, Other: 0/0/0
HW Forwarding: 0/0/0/0, Other: 0/0/0
Groups: 1, 0.00 average sources per group
Sorry, the "ip mroute ..." command not showing what is expected because the source is no longer transmitting here is what we are expecting to see ...
(*, 239.192.12.1), 00:37:43/stopped, RP 0.0.0.0, flags: DC
Vlan254, Forward/Dense, 00:33:30/stopped
Vlan40, Forward/Dense, 00:37:43/stopped
(10.10.40.50, 239.192.12.1), 00:00:02/00:02:57, flags: T
Incoming interface: Vlan40, RPF nbr 0.0.0.0
Vlan254, Forward/Dense, 00:00:02/stopped
configure SVIs vlan 40 and vlan 254 for pim sparse-dense mode
define a loopback
interface loopback 10
desc RP
ip address 10.10.10.1 255.255.255.255
ip pim sparse-mode
ip pim rp 10.10.10.1
Let's see if in sparse mode it works the T flag means SPT flag
Hope to help
Giuseppe
Hi Giuseppe, sorry was a hectic day at work yesterday
Did not try that just yet, the example above is about 40% true setup, in real life is a bit more complicated but I wanted to simplify as making it work at a basic level will then allow me to integrate the more complex multicast traffic forwarding I was able to get the configuration running in LAB but I have a 4331 there with a SW MODULE actively participating ... I had to disable igmp snooping on the particular VLANS to allow the SW to broadcast the frame across the VLAN - since I don't have any IGMP Hosts on the setup, no one is actually requesting this traffic so have no choice .... but I do see some configurations regarding igmp snooping in vlan that refer to making the layer 2 interface a multicast routing interface ... wondering if I can statically configure / specify the SW interfaces I want to participate in MCAST traffic forwarding ... having IGMP disabled makes a mess actually, and Up to now (since I am new to the company and just learning the system) seems like it's been working like that ... there is usually 10-20 devices on the network attached to VLAN 254 and I only need mcast to flow to maybe 2-5 of them instead of all of them
I will try to get back to you if I find some other tricks once I have a chance to play with the 9300 again ... right now just doing a PoC of MCAST in LAB
Maybe this will also help a bit more, showing the stats on the physical interface and it's config
CORE-TRF-DSTRO-SW1-P#sh run int gi1/0/36
Current configuration : 210 bytes
interface GigabitEthernet1/0/36
switchport trunk allowed vlan 40,100,103,203,303,4093
switchport mode trunk
load-interval 30
end
CORE-TRF-DSTRO-SW1-P#sh int gi1/0/36
GigabitEthernet1/0/36 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 4ce1.7675.bba4 (bia 4ce1.7675.bba4)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 10/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:00:25
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 4022000 bits/sec, 433 packets/sec
30 second output rate 100000 bits/sec, 79 packets/sec
13665 packets input, 16820899 bytes, 0 no buffer
Received 11508 broadcasts (11432 multicasts)
0 watchdog, 11432 multicast, 0 pause input
2035 packets output, 315289 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
reliability 255/255, txload 1/255, rxload 11/255
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 00:00:37
30 second input rate 4475000 bits/sec, 470 packets/sec
19107 packets input, 23547198 bytes, 0 no buffer
Received 16117 broadcasts (16009 multicasts)
0 watchdog, 16009 multicast, 0 pause input
2824 packets output, 440471 bytes, 0 underruns
Oleksandr Y.
Well, after this adventurous experience I am getting closed to the actual production environment and I figured I would post this sooner than later, maybe someone has an idea about this. Attached is the drawing representing the Multicast path, once again no IGMP anywhere. The idea here would be to process multicast traffic through the "Traffic Processing Server" (don't mind the reason) but this traffic will be coming back to the same CISCO 9300 and I have to somehow force route this INCOMING traffic out of port Gi1/0/4 further down the line. For unicast I am using a route-map that matches ANY to ANY and send's to that same device out interface Gi1/0/4 ... wondering if there is way to do the same thing with Multicast, because ANY to ANY does not seem to have much effect on this traffic.
IGMP and PIM configuration will most probably just pick up the incoming traffic on Gi1/0/1 and forward directly but it's imperative for my application to pass MCAST over the TOP server and only then out Gi1/0/4
