Cisco ACE How does the ACE deal with Rservers in multiple farms
normbeef
We have an issue where a group of servers are configured across multiple serverfarms,  we are using least connections Algo and we would like to know if the Cisco ACE takes the total number of connections on a per rserver basis,   or is it just per server farm ?
i.e.  if one member has a high amount of connections for an rserver in serverfarm A  that the same server in serverfarm B  is not aware of this issue and is only balanced based on connections for that farm.
hope this makes sense.
aamercado
Level 4
Level 4
Did you get an answer. I have the same question and wonder what you found. Thanks
