Cisco ASA 5505 login problem
Hi, the router says it can be logged into at https://192.168.1.1 but it's not working for me.
Also, I don't seem to be able to enter the ASDM.  I click to install it (have tried various versions) but I don't know what software to run the .bin files w/.
I'm sure these are rookie problems but I've spent a couple of hours and would be ever so thankful for help.
Hi ,
set you network card to get the IP via DHCP, you must get an IP from 192.168.1.0/24 from the firewall.
You must connect your computer in the ports E0/1 to 7 , not E0/0.
Here is the Getting started :
http://www.cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5505/quick/guide/setup.html
Dan
